Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I got up early and said I have to try this again and to take picture to show it not working lol Guess what! I come with my tail between my legs as it worked.
Not really sure why I could not get it working first but it working now. I guess I could not of had the belt work to the top all way around , that the only this I can think of.
So onestopjim it worked for me. Thanks for the help from all.
now that's the spirit! probably kept you up all night
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
awake all night got up 4:30 fixed it and went to work lolnow that's the spirit! probably kept you up all night![]()
- Apr 14, 2003
- Hessel, Michigan
A true snowmobiler.... LOL
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
When I installed on my 2015 I could not get proper adjustment on the stand. I put it down in the trailer and moved it back and forth and the belt/float/adjust worked fine. Before I dropped it off the stand the belt was down low in the secondary, after setting it down and moving the sled the belt was squealing. I then proceeded to adjust, move it back & forth, adjust, back & forth, until belt height was right where I wanted it and no squealing.
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Hey guys having troubles setting my clutch. I can't get the belt to return to the top. I set the belt at the top of the secondary with the adjuster. Then I run the sled and spin the track, once I let off the throttle the belt stay 1/2 down in the secondary. I removed the 3 screws on the back side. Using a 8nd belt.
Martens199
- Oct 1, 2012
Oh I missed that last post. I will try it with the sled off the stand. But I like to set the creep with my track of the ground.
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
ok only 5 days left for the discount get them while you can...
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- 2018 Arctic Cat Hardcore EVO
2017 Yamaha Sidewinder BTX LE
Just recived mine here in Norway. Looks great, installing it soon.
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Ordered, Thank you.
Hillbilly2015
- Oct 22, 2014
- 2015 Yamaha SRviper STX DX
How did you make out??
Martens199
- Oct 1, 2012
Yup once the sled was on the ground the belt went back to normal. But as soon as it's on the stand the belt will not return to the top.How did you make out??
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Why is that ? The belt should return to the top easier, on the stand.Yup once the sled was on the ground the belt went back to normal. But as soon as it's on the stand the belt will not return to the top.
Martens199
- Oct 1, 2012
Yeah im
yeah I'm not understanding that either. Last winter I had problems with this too. When I would get stuck the belt would stay down in the secondary. And I could never creep or drive the sled out afterwards, cause the belt would always squeal and not move the sled very well until the belt made its way back up to the top of the secondary.Why is that ? The belt should return to the top easier, on the stand.
