rtx moose
- Jul 31, 2014
- WATERTOWN,MN
can we upgrade to power steering
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
There is an aftermarket kit, but I think it’s unlikely that Yamaha will offer a kit to retrofit older sleds.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
I wonder what changes were made for itThere is an aftermarket kit, but I think it’s unlikely that Yamaha will offer a kit to retrofit older sleds.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
From the eps description there is feedback to the ecu. I would guess you would need a 2022 ecu...I wonder what changes were made for it
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
ECU for the engine and EPS module, steering post, tie rods, etc.
This is based on previous ATV/SXS/SMB power steering experience. Very limited info on the 2022 technical specs.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Not holding my breath on Yamaha offering an upgrade kit for EPS but Cat just might offer up a kit.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
BOP FOR ME!
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Gse kit works well I’m told. New subframe and steering post and electronics and few other things
sab2022
After market EPS installer says he done with installs .... to many issues
SideHogger
- Apr 16, 2016
- upstate ny
BOP....kiss method and no weight penalty!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
All 22 and up can have power steering added.
Can we add it to a 17 model year?
Hook up the wires to the existing harness like the wiring schematic shows. Two wires to can bus couple ground and power wires then get a 23 ltx le stock flash from a tuner and flash it or have the dealer flash it to the newer sled that matches your set up. Shocks and handle bar controls.
earthling
On the surface, it appears that any winder can add factory power steering with the addition of an updated ECU and possibly gauge. It totals out to about $2100.00 in parts which includes a new ECU. If you don't have IQS then I think you have the issue of either living with that code always being present (unless there is a model with EPS but no IQS). And of course there will be some harness mods but relatively minor (to add EPS fuse, etc). Of course there is the additional challenge of all parts being available.
If anyone wants the spreadsheet, let me know, several of us validated the list of parts so it should be everything needed.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
There’s a guy in Michigan or Wisconsin that is doing the conversion, pre 19 needs to be spliced into harness and he has stuff made up but he does all the installs.19 and newer is just replacing the wire harness with the ps one. It’s nice that it’s the factory version but it costs more than the GSE kit.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Its only 5 wires to splice into the old harness.
$1385 in parts, us$. And need to source a couple connectors for the power steering motor.
Then flash computer to work with eps motor.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Have you physically done this yet or this the “this should work” stage? Just know this guy has done them and said roughly how he goes about it.
- 12K
- 6K
