ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
I had sag issues on my 2017 Ltx se as well. Put in new hygear torsion and twisted center shock springs. No sag anymore even with saddle bags and linq bag. Whole new snowmobile. Phenomenal ride and handling now. Well worth the money. Also bought a set of billet 4 position adjuster blocks. They are also well worth the $.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Where do you get the hygear torsion springs? Anywhere in Ontario?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I ordered from hygear in the us before. Good People to deal with. I also ordered before the Toronto snow show and they brought the stuff over and I picked it up there.
ronzx9
- Jan 11, 2017
- Ohio
I ordered from the web site.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Well that truly sucks!
Something just doesn’t make sense.
You had the skid out this fall for your suspension rebuild, did it have a sag problem before that?
If not, I have to think assembly problem of some sort!
Something somewhere has been changed!
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2021 SRX
2021 Sidewinder LTX GT
2020 Sidewinder LTX GT
2001 SRX
- Drummond Island, MI
- Nope
I think you are responding to my post ref: the rear shock replacement and still too much sag. It is a new sled, the sag started around 1,400 miles, can’t seem to figure out why.Well that truly sucks!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
You are correct! I did not notice that you were not the original OP!
Having severe Add pop up issues again, and so not able to read many of the threads in this post. It took me this long to be able to read your reply(from your reply time to just now)Could not see your response until this morning whereas adds were on top of your thread. Sorry for my confusing things.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
What helps besides marking the add as covered info is go back to previous page and then click on next page and add is gone from post.
DIwarrior
- Oct 22, 2003
- 2021 SRX
2001 SRX
- Nope
Well, pulled the front shock, all good, replaced the rear shock (Qs3) still doesn’t rebound to unloaded ride height. Next step, new torsion springs.
hellflyer
- Dec 2, 2008
Ya! The shock doesn’t influence the ride height much at all just gets really springy when it’s shot. Are the front spring mounts over sprung like (on top of the bolt). Don’t know they could be the other way,but that would cause soft suspension
DIwarrior
- Oct 22, 2003
- 2021 SRX
2001 SRX
- Nope
Well new springs are installed, problem solved. We put in spring # SMA-8JP47-71. Supposed to be a 10 degree more twist in the coil for additional lift. Original diameter. Now we can put some miles on them and see how they hold up!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for the update and resolve of your problem.
Tuckerlee1
(Background, had the skid out this fall, re-greased everything, shocks rebuilt as well and had the suspension setup by a suspension pro. RR upper shaft installed too.)
On my '17 R-TX-SE I noticed today while getting gas after riding some very rough trails in Cochrane aggressively fast that my snow flap was very close to toughing the ground probbaly half way compared to normal. I pushed down on the rear and there was still some travel and rebound but only to the same halfway point. If I pulled up on the rear there was about 4-5 inches of sag to gain. When I had the sled setup we did 3" of sag total with me sitting on the machine.
I tried my torsion springs on 3, still no difference which is weird as the torsion springs should set my ride height/sag.
All appears to look normal under there, I thought I had a blown rear shock but my shock guy said it wouldn't really help hold the rear up at all.
For all intents and purposes, it's riding great still, and these trails are ROUGH! Sometimes when I came to a stop it is at the top as it should but most times it's in that half way down position.
Any advice? I can take a video in the morning
im new on this site I just purchased a 2020 SRX with fox all around and I have 600 miles on it shocks wear saging at the end of year so I rebuilt all shocks and installed the rear of my sled is still saging I just ordered SMA -8jp47-71 hope the springs do the trickI am having similar issues on my 17 LTX-LE .
Sag and bottoming .
Had my shocks done end of ly , so I figured its my torsions , as I constantly carry heavy tunnel bag , and big Linq gas can .
Ordered the 5 position cam from Star .
Will see how that helps.
Tuckerlee1
I also have 2020 SRX it’s the same way wtf Yamaha get your #*$&@ together 20 grad for thisI have a 2020 ltx le and its doing exactly the same thing. I put transfer blocks to stiffest setting #3 and no difference. Dealer changed front shock in rear skid said it was blown. Got it back and still does the same. Its back at dealer they are replacing rear shock and torsion springs now. Sled has 1078km on it so far.
Mototown
If you putting on more than 3000km a year , I would recommend you rebuild your rear of rear shock with a nitrogen charge of 200 -215 psig with it done right before the season starts for best results. Most of the sagging problems will be fixed .
