Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Great? I'll have to scope that out.You have to make sure the anti-seize is for high temperature. The stuff I used was good for 5000 degrees and is still there.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Copper anti-sieze is what you want, not just regular anti-sieze. Permatex makes some that's at most auto parts stores that is 2000* stuff. Otherwise the best stuff on the market is made by Wurth NI2400, it is pure nickel anti-sieze.
Doc Harley
- Oct 17, 2016
- Here & there
The stuff I put on is rated at 1800°. Someone else put on copper @ 2000° and he says that all disappeared for the temps.
Rat farts!!!!
Rat farts!!!!
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Rat farts!!!!
The stuff I use has nickel in it like Allen said.
Doc Harley
- Oct 17, 2016
- Here & there
Napa, advanced, auto zone. None stock it.
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
The stuff that "disappeared", did the bolt still come out easily?
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
I just checked amazon and copper anti seize is 2000 degrees. Is this the stuff I need to buy?
Doc Harley
- Oct 17, 2016
- Here & there
Go with the nickel. Rated at 2400. Kinda to be safe. Already did it once in aluminum.I just checked amazon and copper anti seize is 2000 degrees. Is this the stuff I need to buy?
O'Reilly auto parts. Will have tomorrow morning. 8oz for $26.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm running 5 of the 6 bolts for now until I get my rescue bit and I don't have any exhaust leaks, just an FYI. I did notice that the hex bolts I installed that appeared chrome like when installed are now very yellowish from the heat. They are grade 8.8 from Canadian tire, I'm not sure if they were stainless or just coated but they sure discoloured from the heat.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
this is another small issue I would have liked to see fixed during testing. Like the mount bolts and rollers. Hopefully some recalls coming
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Today I took my bolts out one by one and nickel anti seized them. They came out with a good squeal. The threads show signs on galling after 40 miles. I hope the anti seize works.
Definatly a must do.
orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
Replaced all the exhaust bolts and I would not recommend the stainless steal bolts. Snapped the last one off but was lucky enough to get a vise grip on it to remove it. Seems to me like I couldn't get them to torque to specs. Removed and replaced with flanged head bolts with anti-seize. All good now.
DMCTurbo
- Nov 12, 2005
What were you torquing them to? 2 stage torque, 9ft/lbs then 18ft/lbsReplaced all the exhaust bolts and I would not recommend the stainless steal bolts. Snapped the last one off but was lucky enough to get a vise grip on it to remove it. Seems to me like I couldn't get them to torque to specs. Removed and replaced with flanged head bolts with anti-seize. All good now.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I've had bad luck with stainless bolts and screws. They are soft and snap easily and the worse part is you can't drill them out if they snap inside anything. I'm still thinking about drilling out the threads on the turbo and putting bolts nuts and washers. From what I can tell you can do that on 4 of them. This way even if you break them all you do is put new ones in.Replaced all the exhaust bolts and I would not recommend the stainless steal bolts. Snapped the last one off but was lucky enough to get a vise grip on it to remove it. Seems to me like I couldn't get them to torque to specs. Removed and replaced with flanged head bolts with anti-seize. All good now.
orangecrush
- Oct 23, 2012
- Lino Lakes, MN
Yep. They were just too weak.What were you torquing them to? 2 stage torque, 9ft/lbs then 18ft/lbs
