DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
dude...drill it and heat that f*cker up with mapp gas and use an ez outmost big box stores have them....if you use the old z1 gasket with rtv copper you have a chance.....but they leak sometimes even with all the bolts...so ...
I did drill it, broke the bit in it, told dealer the issue I had, Yamaha wanted to inspect the sled....dude...drill it and heat that f*cker up with mapp gas and use an ez outmost big box stores have them....if you use the old z1 gasket with rtv copper you have a chance.....but they leak sometimes even with all the bolts...so ...
Just ordered a rescue bit to drill it out. I'll get it, not worried after talking to "The Original Rescue Bit" people. Fantastic to deal with. A positive experience.
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
You could just drill it out and replace it with a bolt and lock washer and nut. I read in one of Td exhaust threads that 5 bolts were more then enough if the middle hard to get at bolt was a problem with some exhausts.
orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
Does anyone have the length of the exhaust bolts? I'm going to try and replace them this weekend and the sled is not near a hardware store. I went to pick some up and they had a lot of different M8 x 1.25 grade 8 bolts to choose from. Also just regular lock washers work? Thanks in advance.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
22mm in length.
Use a stainless bolt, grade 8 means nothing as it's not a strength issue, it's the material it's made out of.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I removed my exhaust today and all six bolts came out very easy. I only have a few miles on it so that probably explains why they came out so easy. I think I'm going to change out the bolts but was wondering about drilling out the threads and putting bolts and nuts on instead. I think this can be done on 4 of the six bolts.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
My bolts came off very easy but my 8x1.25 hex heads don't seem to fit. Has anybody else found this?
XP123
- Dec 25, 2016
- Chautauqua NY
I would bring the original bolts with you and check to see if the nuts that size will fit. I guess you can run a tap through the holes on the turbo and then try the new bolts.My bolts came off very easy but my 8x1.25 hex heads don't seem to fit. Has anybody else found this?
hooknbook
- Mar 3, 2016
- hartland mi
- Side winder
- Bear lk
I've been using the stock bolts, I've had them on and off about 6 to 7 times now and they work perfectly.... Just food for thoughtMy bolts came off very easy but my 8x1.25 hex heads don't seem to fit. Has anybody else found this?
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
after doing mine, i just want to stress what has been said, if you haven't done this, DO IT! easy to see you WILL regret not doing it sooner if you wait. even if just to never seize them if nothing else. thank you for the heads up to all.
XP123
- Dec 25, 2016
- Chautauqua NY
Did you replace yours with regular bolts?after doing mine, i just want to stress what has been said, if you haven't done this, DO IT! easy to see you WILL regret not doing it sooner if you wait. even if just to never seize them if nothing else. thank you for the heads up to all.
hooknbook
- Mar 3, 2016
- hartland mi
- Side winder
- Bear lk
I put never seize on the stock bolts one time.It was gone the next time i took it apart the copper stuff as well...
- Dec 6, 2016
- saegertown pa
yes, i sent the wife to the parts store with the torx bolt and she brought back 8.8 & 10.9. put the 10.9 on, alloy steel, quenched and tempered. Cap Screw Flanged Hex Head Class 10.9 M8 1.25 x 20Mm Dorman 875-420Did you replace yours with regular bolts?
actionjack
- Apr 9, 2005
Thank you. I of had the bolts with me and they seemed like different threads. I tried the 1.25 pitch when I got home and the hex heads are installed with anti-sieze and Nord locks. Silly to have those T50s behind that pipe like that.I would bring the original bolts with you and check to see if the nuts that size will fit. I guess you can run a tap through the holes on the turbo and then try the new bolts.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Too much heat, right? options?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
You have to make sure the anti-seize is for high temperature. The stuff I used was good for 5000 degrees and is still there.
