stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I found this on-line.
Good for 2600 degreesF
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Looks like you got me beat! 2600 wow. that's some good stuff!
Turboflash
- Mar 18, 2019
- Southern MN
IF flanges are flat and gasket is good, will not leak at 18 ft.lbs. I've seen quite a few muffler flanges that were warped/dimpled where the bolts go due to over-tightening. I have to straighten them before reassembly.Are you going to factory spec of 18 ftlb which Does not seem like much
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I would not use stainless steel unless you first clean up those stock rough threads in that turbo cast iron! And apply that nickel!
Ever have do drill out a SS bolt?
I do not care what type drill bit is used, without the aid of a drill press, it’s gonna take many bits and lots of patience!
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I have used an endmill to drill out bolts, i find it works better since you dont get a drill point wandering aroundI would not use stainless steel unless you first clean up those stock rough threads in that turbo cast iron! And apply that nickel!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for that bit of knowledge. I shall try and remember that but hope I never have to drill any SS with a hand drill and bits!I have used an endmill to drill out bolts, i find it works better since you dont get a drill point wandering around
Have tried many different bits ordered through multiple suppliers like McMaster-Carr, and they all dull quick!
Can this endmill be used on a hand drill?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Got ya beat by 200°
I'm getting you used to getting beat
Cuz i'm gonna try to get to the UP next year & i'm hunting "Jon's that have Fun"
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
As long as it isn't carbide you should be ok. Carbide will chip and be destroyed quickly. You will Want To turn it as fast as possible. holding it straight and feeling what it is doing will be key. Just don't spend too much $ on one in case it doesn't work for you. I have done it, but to be fair, I have allot of experience.Thanks for that bit of knowledge. I shall try and remember that but hope I never have to drill any SS with a hand drill and bits!
On a side note, I have used a worn endmill and turned it backwards to back out a broken screw.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I just pulled the stock bolts and tossed into garbage last night. 2022 sled with lots of anti seize and SS bolts I threaded them through all the way by hand.. This is a new sled and is a must do with NEW SLED.. once you get the threads lubed up good and keep changing bolts(every season) from NEW you will have no issues. The issue with these bolts and this issue is guys are over torqueing the bolts and waiting to apply anti seize till after the miles are piled on.. You have to get to these bolts from new and stay on them with fresh ones and anti seize. Use plenty of heat Before removing them.I would not use stainless steel unless you first clean up those stock rough threads in that turbo cast iron! And apply that nickel!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Da U.P. ? Not sure the UP can handle a OCDGot ya beat by 200°
apexgt4life
What grade ss you useI just pulled the stock bolts and tossed into garbage last night. 2022 sled with lots of anti seize and SS bolts I threaded them through all the way by hand.. This is a new sled and is a must do with NEW SLED.. once you get the threads lubed up good and keep changing bolts(every season) from NEW you will have no issues. The issue with these bolts and this issue is guys are over torqueing the bolts and waiting to apply anti seize till after the miles are piled on.. You have to get to these bolts from new.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Grade 5 they areWhat grade ss you use
apexgt4life
Got some and was doing some bench testing to compare. Im second guessing using stainless hardware. Put in vice to see what they would handle and was snapping heads off. Based on my research they are not even designed to handle the recomended torque spec.Grade 5 they are
Main concern is if one does seize, will not be able to apply any force to remove.
In comparison. Did same testing with factory bolt and it did much better and actually pulled threads out of nut and did not snap
Probably overthinking but going to stick with oem or someing comparable.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Dam!!that's a big enough bottle for all our to share!!LOLI found this on-line.
Good for 2600 degreesFView attachment 163146
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I found the stainless bolts to be extremely weak as well. Nothing works better than the stock muffler bolts as long as you can get a torx bit on them properly. With the aftermarket mufflers however it gets hard to fit them in all the holes. I've been using small head (12 pt 10mm wrench style) header bolts in those couple of tight areas, but even they are soft and want to stretch and break the heads off. Need grade 8 style header bolts and they are hard to come by in metric no the grade 5 stuff.
