**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if the trails are tight...put the bar back in for corner burning...and yes the skis have to go...I put on a set of cat procross skis from a 16 and even thats better for now..
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Any harm in removing the shaft? I have the blocks out but find it still doesn't transfer the best.
Fleecer
- Jun 13, 2014
- 2019 SRX
Nope, I do it all the time.
WINDER1987
It depends what you weight really I weight 220 dressed had mine removed and completely tore my 4th wheel kit center wheels apart and bent the steel shaft that hits when there's no blocks to stop it. I now have my shaft and blocks in but want to try the racewerxAny harm in removing the shaft? I have the blocks out but find it still doesn't transfer the best.
Pstn head
I have the Raceworks coming, will let you know how it is. Most likely next weekend.It depends what you weight really I weight 220 dressed had mine removed and completely tore my 4th wheel kit center wheels apart and bent the steel shaft that hits when there's no blocks to stop it. I now have my shaft and blocks in but want to try the racewerx
DMCTurbo
- Nov 12, 2005
So with the shaft and blocks removed it hit and destroyed the rear wheels?It depends what you weight really I weight 220 dressed had mine removed and completely tore my 4th wheel kit center wheels apart and bent the steel shaft that hits when there's no blocks to stop it. I now have my shaft and blocks in but want to try the racewerx
WINDER1987
I'm 220 dressed I wouldn't do it unless u are very lightSo with the shaft and blocks removed it hit and destroyed the rear wheels?
DMCTurbo
- Nov 12, 2005
That's not goodView attachment 125341 View attachment 125342 View attachment 125343 Yes
WINDER1987
Nope wouldn't recommend it atleast keep the rod in i bent the metal back and am putting the racewerx one inThat's not good
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
You have the oversized wheels! That put them a lot closer than stock. You'd be fine with stock trihub.
DMCTurbo
- Nov 12, 2005
Ok may try it then.You have the oversized wheels! That put them a lot closer than stock. You'd be fine with stock trihub.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
I have the blocks out, but left rod installed. I honestly wouldn't want it to transfer any more than it does now. Lifts the skis 4"-6" at will, and will loft the front end on any small grade on the trail.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
AGREE 100%I have the blocks out, but left rod installed. I honestly wouldn't want it to transfer any more than it does now. Lifts the skis 4"-6" at will, and will loft the front end on any small grade on the trail.
yamaha06
Do you guys notice the metal on metal contact with the blocks removed? It would be nice to find something to put on the shaft that is very thin and that will actually stick on there.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Rubber garden hose or pvc pipeDo you guys notice the metal on metal contact with the blocks removed? It would be nice to find something to put on the shaft that is very thin and that will actually stick on there.
