BlueApexXTX
Yes I did... Running Powder Pro skis!Did you loosen your limiter strap out to the last hole as well?
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Yes
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Out for some pulls last night with a mod etec and JLR's fancy Nypex. I think my blocks are going back in. I'm a bit past 700 miles now and the rear end has definitely loosened up a bit. Getting more transfer than I need and had to back out of a few pulls.
Which model Sidewinder?
LTX LE.
Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
Heard the n/a nypex was faster than the sidewinder
I think he got one pull out of several, but I had to lift. It is fast for sure, but I think I'm about 2 MPH faster right now.
Regardless, that sled is working well. It would crush a stock Sidewinder.
Reaper
- Nov 10, 2005
Best top speed so far on speed has been 116 mph ideal conditions. lakercr, what are you getting?
Just pulled 120 on my GPS an hour ago. Still some chicken on that bone with clutching, but not going to tune for these conditions until they're here to stay.
Reaper
- Nov 10, 2005
Nice, what have you done to it so far? Yeah, its done here until we get more snow.
Suspension about the same as yours, clutching, gearing, and an Evo Stage 1 tune from Mike at Sandale.
Sled rips.
Sled rips.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Did you loosen the limit straps to the last hole?I have the blocks out, but left rod installed. I honestly wouldn't want it to transfer any more than it does now. Lifts the skis 4"-6" at will, and will loft the front end on any small grade on the trail.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
second last hole
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
137 right? your weight? Compression? Rebound ? Torsion spring block on 1 i assume?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
It depends on rear wheel size,if stock 8" ok,but if aftermarket 8.5 not so good,you will chew them up in no time.Any harm in removing the shaft? I have the blocks out but find it still doesn't transfer the best.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Heavier riders will have more problems... and all will most likely bend the tabs..
