John Deere Hygard.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
After first service I used full bottle of Amsoil chain case lube which fills chain case to top of sight glass.
Interesting thing, I had sled on a sled lift while re torquing my studs, as I was spinning track by hand I took a look at the sight glass and noticed oil at the bottom of the glass, got to imagine while riding there isn’t much oil in the bottom of the case even when using 16 oz.
I run 1/2 litre which is a fair bit, the sight glass is completely submerged. While running it on the stand there is no oil visible in the sight glass, all is whipped around the case.
Now just think if there was only 300ml (or whatever factory spec is) in the case - I don't think that's enough oil in there.
MS
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
True, not sure what Yamaha was thinking with that amount of oil.I run 1/2 litre which is a fair bit, the sight glass is completely submerged. While running it on the stand there is no oil visible in the sight glass, all is whipped around the case.
MS
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Klotz is the only chain case lube I have used on all my sleds and all the ones I serviced I have never had and issues I just fill it to the top on sight glass. And works our as RockerDan states 16 oz.I realize hundreds of posts have been written on this topic, but, just to confirm, is 16 oz of Klotz chain case lube still a good quantity/type of chain case lube to use? Thanks.
Dr. FeeLGooD
I have been using yamalube in all components an all my Yamahas for 18 years. I am switching to something else because Yamaha does not desreve my business any more.
Just don't go overboard.True, not sure what Yamaha was thinking with that amount of oil.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
X2Just don't go overboard.There is a point when too much will come out the vent. I've been going just a little over spec like Hammer70
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Thanks.. Amsoil I used comes in 16ozJust don't go overboard.There is a point when too much will come out the vent. I've been going just a little over spec like Hammer70
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Even with over filling with 500 ml, there is no evidence of it coming out overflow
Ms
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
I use Amsoil synthetic 75w/90.My top gear just went at 6,000 miles, tuned from day 1. I think it has worked well. I use the top of the sight glass as level indicator to get a little extra in, don't want it too high pulling metals away from the magnets although they are probably strong enough to resist that.
