Its fine! Thats what happens when you ride your sled. Its just a machine. The fun I had with Farmer and I bet others will say same. Priceless. Get'er done Tom!For sale lightly used. Wife’s sled.
Tunnel Patch on.
Looks great. I like that you have holes there.View attachment 174329View attachment 174330View attachment 174331Hole in exchanger. Had to come out.
Tunnel Patch on.
Thanks. I thought it should have a way to get that heat out under the tank.Looks great. I like that you have holes there.
Is that Tube between the engine mounts stock? Was thinking about doing that for my Viper too.View attachment 174329View attachment 174330View attachment 174331Hole in exchanger. Had to come out.
Tunnel Patch on.
I believe so. I’ll no more once I get new exchanger.Is that Tube between the engine mounts stock? Was thinking about doing that for my Viper too.
Thanks! Sadly is time before I get mine back in so...I believe so. I’ll no more once I get new exchanger.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Damn, your this far into it just put a new tunnel on it.
Looks like fun!
Looks like fun!
Not my call. I do what I’m paid to do. This is what he wanted. I would have just found a new chassis and dropped motor in it but when you have this amount invested hard to change the direction. This will work and most likely be stronger then the tin foil I have worked with.Damn, your this far into it just put a new tunnel on it.
Looks like fun!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I plated my tunnel about 4 or 5 years ago when it separated from the heat exchanger and it is still holding up strong.
Can't believe how cheesy that area is.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Nice work Tom. That thing will be stronger than new.
Thank you!!Nice work Tom. That thing will be stronger than new.
Looks Great! Mine next. Actually may ask for help with wrap if you are up to it and no snow thing.
I think we can work something out for you.Looks Great! Mine next. Actually may ask for help with wrap if you are up to it and no snow thing.
- 35K
