Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Is the winder tunnel the same as the Viper tunnel? Just thinking that there is too much thrust on the snap ring, when changing the bearing on the drive shaft I had to ratchet strap the tunnel together in order to get the snap ring in the groove. I don't believe that a snap ring is made for thrust loads.
x600c
- Mar 11, 2013
- maine
- Sidewinder
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Update-
The dealer just called , apparently the clip on the jack shaft came off. Seems like a strange thing to happen. Anyway they orders all the parts.[/QUOTE
The clip Popping off is common. That's all that is holding the gear from moving inward and when it does it pops out of gear. I'm having a spacer made up to support the clip.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Can you take some pics of your spacer mod?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
When it' done.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Great,When it' done.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Sure I would think so.Would this being worn out/broken be causing the sled to keep poping out of gear?View attachment 138952
x600c
- Mar 11, 2013
- maine
- Sidewinder
I hope so just ordered a new top gear and reverse gear. They meshed hard enough to wreck both
This happened to my winder last march. My friends did this last week. both had about 2000 miles on them. Top gear has about .080 of slop and thats a lot. The gear can move ways it is not supposed to and breaks the fork pads. Also can push the circlip behind the gear out of its grove and the chain will grind off aluminum from case. Mine just broke the pads so it would pop out of gear and grind. Shut it of and restart and it was able to drive back but popped out several times. my friend moved the circlip and was not able to drive it. I have heard some say just replace the top gear every year. Not a good design in the $15,000 machine!
On my 18, I installed both washers that are located beside the top gear on the inside only. I then had a washer that was half as thick that I put on the right and the clip would still fit. This helped to keep the splines further engaged.
But ya, this chaincase needs a major re-tooling.
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
The exact same thing happened to me. My upper gear bushing wore so bad and was flopping around that it appears to have knocked off the circ clip on the jackshaft.Update-
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
That is unreal. I guess I'll be checking mine at every chain case oil change.
theewarrior
Anybody using just regular old gear oil 80 W 90 seems to be working fine for me 3500 miles mostly 270
I would be very interested to see how your gear fits the shaft???Anybody using just regular old gear oil 80 W 90 seems to be working fine for me 3500 miles mostly 270
- 12K
