gpxsrx
- Dec 15, 2009
- way to many 2 strokes
Ended up purchasing bushings from McMaster-Carr part number 6381K563
gpxsrx
- Dec 15, 2009
Bushings $3.00 a piece
No ptf coating on them but should work fine.
Did they seem to fit the shaft a bit tighter than stock?Bushings $3.00 a piece
No ptf coating on them but should work fine.View attachment 148699
gpxsrx
- Dec 15, 2009
Have not pressed one in the gear yet but just putting it on the shaft seems tighter.Did they seem to fit the shaft a bit tighter than stock?
gpxsrx
- Dec 15, 2009
Finally got bushings pressed in which I got from McMaster Carr. Had to cut 2mm off the length. Also had to sand inside a bit to slide over jackshaft after being pressed into gear.
gpxsrx
- Dec 15, 2009
Has anyone come up with a better turbo oil drain hose from turbo to stator housing? Last year the hose fell off and oil light came on shut her down.
I was able to repair on trail.Bought a new hose from Dave and a updated nipple barb but still don’t like the fitment. Just wonder if anyone else has had issues? Thanks.
Cant you make a metal line? Has to get awful hot for rubber.
gpxsrx
- Dec 15, 2009
I’m trying to source a different set up for sure but that’s how it comes from Hurricane. Found thisCant you make a metal line? Has to get awful hot for rubber.
gpxsrx
- Dec 15, 2009
I’m trying to source a different set up for sure but that’s how it comes from Hurricane.Cant you make a metal line? Has to get awful hot for rubber.
The problem is the two barns are not in line and if you cut the rubber hose to short the hose will fall off.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I beleive mine is silicon and it's been fine ,even forgot to tighten the gear clamp one time and ran for a 500km weekend when I noticed a little oil in the side panel. Never came off just leaked Abit.
hellflyer
- Dec 2, 2008
It needs to flex, turbo is not solid mounted to the motor. Think you'd do damage to the stator cover if it was a solid line.Cant you make a metal line? Has to get awful hot for rubber.
gpxsrx
- Dec 15, 2009
Mine also just cut too short and I don’t like that the clamp does not go up high enough because of the cap screws holding barb on.I beleive mine is silicon and it's been fine ,even forgot to tighten the gear clamp one time and ran for a 500km weekend when I noticed a little oil in the side panel. Never came off just leaked Abit.
ViperRob
- Oct 16, 2016
- Boone
- 15 Viper
Let me know what u come up with. I hate the design as well. Going to be installing a GTX2871 this weekend. My hose is junk already. Also be hooking it up to water as well to cool it.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
So I went with this “Getto” setup last year and it held up much better than the POS rubber hose.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I also used copper washers and locktight to seal the threaded barb fitting. The junk a$$ rubber o-ring was leaking from the start.
