jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Hey mototown its the “ fun factor” your missing here. Come on!! So it’s like this > One can only have fun on a ski doo not a Cat , Yamaha , Polaris !!!!! They call it the “ski doo feeling”. Can’t you feel it?
number1kyster
I rode a 900T today for the first time. I thought it was extremely snappy in sport mode. It felt like a 2 stroke.
The 180 version should be a runner.
vmxrdr
- Feb 3, 2012
Buds on dootalk have declared the weird throttle response on 900t is fixed on the Mach Z they can tell from sitting on one at a static display?? You get used to the lag and surge eventually anyways. The Mach Z anti lag launch on Snowtrax sneak peek did not look impressive. I assume traction must have been terrible for it to look that lazy. I must admit it does sound cool in the video when AJ pokes the throttle a bit. Stock Winders sound pretty lame which is nice on a 400 km per day saddlebag trip but isnt very sporty.
20/80
You would think Somebody would have lined these two stock sleds up and shot a vid on youtube by now, also is there a Vid on a the two 998's with turbo's lining up.
number1kyster
My dad has lined up with his buddies 900T. Both stock. They are close until 90 and then the 998 checks out.
20/80
That's interesting, the 900t 150hp hung and was close with the Winder till 90mph, not sure how fast a stock winder will go but the new 900t r maybe will be able to close that gap from 90mph on and may not be as easy for the Winder to pull away, all it would take is the Mach get the jump on take off, Ski doo put launch control on the Mach for a reason.My dad has lined up with his buddies 900T. Both stock. They are close until 90 and then the 998 checks out.
number1kyster
It'll likely take a long stretch to overcome the deficit, assuming the Mach Z boys can find a stock SW to run.
20/80
It would be hard to find a stock SW.
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
Mach Z at 548 lbs
Sidewinder at 590 lbs
info from the forums
NYTurbo
Anti lag is only good if you have the traction to support it.
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
Spec sheet that came with my 2019 SRX said 603 lbsMach Z at 548 lbs
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Put me on it 880 lbsMach Z at 548 lbs
Bigblue1
My sled weighs 568 lbs. So, I just have to lose some weight to equalize a bit.Put me on it 880 lbs
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Are dealers limited to how many sleds they can spring order for customers ?My sled weighs 568 lbs. So, I just have to lose some weight to equalize a bit.
Mototown
I know last years srx in Canada was limited to a # . So I’m guessing each model has a limit again this year.Are dealers limited to how many sleds they can spring order for customers ?
- 16K
- 98K
