![](/styles/vip.gif)
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Have a Cat buddy looking to gear up his Cat that only has 24/50 in it now.
He's looking for a stock set of Winder takeoff 21/41 gears and chain kicking around. PM me please if you have something to swap for his 24/50 or want to sell your set. Thanks!
stgdz
- Mar 27, 2021
- Buffalo MN
Why not just go bottom 42 gear?
KnappAttack
- Feb 19, 2004
- Welch MN
Because he doesn't need or want 140 MPH gearing with a 24/42.....
Should be lots of stock winder gear sets out there on the shelf I'd imagine.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Mike if you don't find what you're looking for I have a 45 tooth bottom sprocket (Venom Products) that would work with a 90 link chain, have converted a couple of Thundercats that way.
stgdz
- Mar 27, 2021
- Buffalo MN
Tcat is a 96p chain, can you run a 44/46 tooth lower with it? Probably would load the turbo like no other.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Tcat is a 92 pitch chain, no you need a 90 pitch chain on the smaller bottom gear.
stgdz
- Mar 27, 2021
- Buffalo MN
Is 50 the smallest I can go? I don't have charts in front of me.
Turboflash
- Mar 18, 2019
- Southern MN
24/50 shows as 92 pitch chain.
The only other 92 pitch ratio in Cat manual is 23/51.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Yamaha shows a 49tooth lower gear on the alterate parts! I always wonder if it would make much difference? I'm assuming it uses the 92 pitch chain still? I'm running 24/50 now and love it
NYTurbo
Keep in mind you don’t want a huge dog leg
Turboflash
- Mar 18, 2019
- Southern MN
IMO you won't notice any difference, and you'll have a steeper dog-leg.
24/50 = 2.08 ratio
24/49 = 2.04 ratio
24/50 = 2.08 ratio
24/49 = 2.04 ratio
hellflyer
- Dec 2, 2008
That's what I figured!
NYTurbo
24/49 would be a substantial dog leg
hellflyer
- Dec 2, 2008
Wonder what chain they expect you to use with it or combination of gears /chain?
- 33K
- 7K
