Blueaway
- Nov 16, 2016
- Alliston
- 2023 srx
I'm just want my sled to be reliable as It can running extra boost . Stock BOV safe with power trail Tune Or should I replace with After market BOV Thank you
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
You should be fine with stock.
Blueaway
- Nov 16, 2016
- Alliston
- 2023 srx
Thank youYou should be fine with stock.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
stock works fine for that boost level. Still a good idea to verify, tighten all connections just to be sure no leaks.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
no worries whatsoever...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
X2, cant hurt to check for leaks as Ben showed last season on a stocker. But the stock BOV seems to be very good til 17psi, and on my(zero mile) sled it went much higher, while others with a season under their belt saw seeping.stock works fine for that boost level. Still a good idea to verify, tighten all connections just to be sure no leaks.
Definitely not a MUST have though.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
agree.... until you get to the big tunes its a non issue.... on my 11 z1t...i ran 24 lbs with it and other supposed must haves and out was fast and just fine... so was my 12 1100 and my 16 1100
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yeah, on my 12 I never touched any of the charge area...stock BOV and stock charge tubes all were fine and my boost gauge was spot on what Ben told me each map should be for PSI....I know we all get overhyped on having everything perfect on these sleds but YAM did a heck of a job with these machines.
Its just what happens before we have snow and are riding, to take the edge off...spend,spend, spend...lol
- 17K
