Fleecer
- Jun 13, 2014
- 2019 SRX
You can adjust with the clickers but only fine tuning. They are not meant to be for huge RPM adjustments. 50 rpm per slot change if I remember correctly.
I have the TAPP also and will be buying the smaller +1 rollers or even the stock DOO size.
This clutch is so smooth and quiet. It is a big expense BUT if ordered correctly you not need additional tuning components.
Be prepared to run shallower angle helix or stiffer springs in the secondary. The TAPP shifts very aggressively/hard and will blow through wimpy secondary springs or steep helix combos
How shallow of a helix are we talking? Is the stock 35 too steep?
Are the +1 rollers enough to support 300hp?
Dave Forsyth
- Aug 12, 2016
- Sicamous
- XS1200 Turbo & 2018 850 175"
- Sicamous BC Canada
- www.tappclutch.com
www.tappclutch.com
Calibration Guide online
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Dave, rumor has it you have been working on a secondary? Care to fill us in?
Dave Forsyth
- Aug 12, 2016
- Sicamous
Nothing until testing is done.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
The color options looks sweet! Is there an additional cost for the different colors?
Dave Forsyth
- Aug 12, 2016
- Sicamous
putz21
- Apr 15, 2013
- Tomahawk, WI
Pieces of art!!!
Fast
- Sep 25, 2018
Hey Mike, i hope you test the PB80 this year i'm leaning towards buying one for the simplicity and seeing them capable of handling 300hp now plus no rattleI'm curious too.
But have a look here.
PB-80 For SideWinder, ready for primetime.
Kind of an interesting statement from a fellow in know (68gmc) who has mega turbo and clutching experience with all the brands.
Is it really possible a PB80 could perform as well as a Tapp? I think it could, its good enough that Precision Sports is putting the dual spring PB80 setup on their 300+ HP Ski-Doo turbos.
Have a buddy in NY that is running a couple dual spring turbo pb80s on 290R tuned Winders. I have my dual springs in hand, but will need to machine the cup and spring seat before trying it out. My buddy is loving the dual spring pb80 setup.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I have the TAPP clutch. Now that I have my head wrapped around what it wants and how reacts to adjustments I believe that I have made the correct choice in clutch upgrades. What a piece of precision equipment. The BEST primary made in humble opinion. Yes you pay for it, but a piece you can move from sled to sled for years to come. I have 6000 miles on mine and aside from initial set up I have no complaints.
Fast
- Sep 25, 2018
How much is the tapp calibrated tax in?I have the TAPP clutch. Now that I have my head wrapped around what it wants and how reacts to adjustments I believe that I have made the correct choice in clutch upgrades. What a piece of precision equipment. The BEST primary made in humble opinion. Yes you pay for it, but a piece you can move from sled to sled for years to come. I have 6000 miles on mine and aside from initial set up I have no complaints.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
If I was to go to a different sled can the taper section, were it mounts to crank shaft be changed to different taper?? Or do I have to buy a sled with same taper.?
Fast
- Sep 25, 2018
I'm guessing noIf I was to go to a different sled can the taper section, were it mounts to crank shaft be changed to different taper?? Or do I have to buy a sled with same taper.?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
You may be able send it back to have the inner sheave changed to match a different taper.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
x2I have the TAPP clutch. Now that I have my head wrapped around what it wants and how reacts to adjustments I believe that I have made the correct choice in clutch upgrades. What a piece of precision equipment. The BEST primary made in humble opinion. Yes you pay for it, but a piece you can move from sled to sled for years to come. I have 6000 miles on mine and aside from initial set up I have no complaints.
Dave Forsyth
- Aug 12, 2016
- Sicamous
- 43K
