ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Do the BOP shaft upgrade, it’s gonna break if you ride even moderately hard. I bent my RR shaft and was lucky enough to catch it before disaster struck.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
when I got my spring order 998 and I addressed the loose bearing fitment issue so many have had with drilling divets in the shaft (on bearing seat) and adding retaining compound eventhough the bearing was a fit snug
The retaining compound did a excellent job to the point I needed to apply heat and use a puller to remove!
I am going the same route with my new skf bearing since I am confident it works
If anyone attempts using the retaining compound method to lock the bearing here are a few suggestions
- mesure bot inner race and shaft to make sure you are within spec of the retaining compound tolerances
-Drill 4 divets with a drill bill
-Clean both inner race and shaft spotless then clean with alcohol
-Coat shaft with retaining compound and assemble (put brake rotor and gears so you can install retaining clips on both side)
- then leave it alone for 24hrs to give the chance for compound to set!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Here's a pic of the shaft after the
old bearing removed after applying heat to burn retaining compound and puller
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
It’s important to note that there are different compounds of loctight. I used 638 green, it can fill gaps up to .010” others aren’t as strong or won’t fill gaps that large. If you have over .005” clearance, I wouldn’t even bother, you need a new shaft. I have both retaining compound and BOP wedge because mine had spun some and had .005” clearance shaft too bearing.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
620 says .015 but I wouldn't use it on a clearance issue close to the maximum specification..It’s important to note that there are different compounds of loctight. I used 638 green, it can fill gaps up to .010” others aren’t as strong or won’t fill gaps that large. If you have over .005” clearance, I wouldn’t even bother, you need a new shaft. I have both retaining compound and BOP wedge because mine had spun some and had .005” clearance shaft too bearing.
Imo stay well within to specific tolerance.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Decided to run the stock track one more season before swapping to1.50
RAMSOMAIR
1.50...... gonna slow that girl down??
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes sir but will be fun down low1.50...... gonna slow that girl down??
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Nice workbench, plenty of light.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
What size studs are those ?View attachment 154911 Getting track ready to go back in adding studs to the outside edges and sharpening the existing one
Decided to run the stock track one more season before swapping to1.50View attachment 154910
I had to change my track , due to OWNER NEGLIGENCE , and replaced with the same 1.25 stock track but with 1.325 studs rather than the 1.5 that I previously had (bought a used set up as was considering selling ) and my SOTP feeling was a big difference in all aspects of gription .
I would have gone to the 1.5 with 1.75 + studs , and in fact may still , if I decide to keep the sled OR put that set up on what ever sled I buy , which would be an SRX or an LTX-LE , which will have a 1 or 1.25 stock track .
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
They are 1.450 megabites not sure if I am going the put the same on the outside I may go with gold diggersWhat size studs are those ?
I.am definitely going 1.5 track after next season
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I actually like my sled this year with only the igrips if they held up better. They are coming out and I’ll either stud it or prestudded is going in. With my weight on the sled it turns better on tight trails that I run with out studs
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Will there be any clearance issues with a 1.5 track with studs? This is what I want to do this summer even before I threw a stud through the rear exchanger
Turboflash
- Mar 18, 2019
- Southern MN
Depends. How long are the studs and how do you plan on tensioning your track?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I don’t need a lot of penetration, I’m just a trail rider and would like to run woodys megabites 1.75”on a storm track 1.5”. Is it really that close?
