Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Need to replace my stock 21t gear. What's the flavor of the day (who's gear is best)stock winder....
Thanks guys....
Thanks guys....
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
DMC 21 Tooth Top Gear & Super Bushing Sidewinder Thundercat 8KC-E769A-11-00 | eBay
NOTE: Our DMC gear / bushing solution allows you to retain your reverse function. "DMC Brass Shift Fork Pads". But we have also seen a disproportionate majority of top gears on sleds that are boosted, studded, and or ridden aggressively that have failed and either ruined a expensive trip or left...
www.ebay.com
Best show in town
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Prevost Performance sells a replacement bushing, simple install. Reuse your original gear. $120 Cdn.
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
$120.00 for the bushing alone? Or is this a new gear setup with a replaceable bushing?Prevost Performance sells a replacement bushing, simple install. Reuse your original gear. $120 Cdn.View attachment 163241View attachment 163242
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Where can I purchase in US or is it easy from Canada$120.00 for the bushing alone? Or is this a new gear setup with a replaceable bushing?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
While the Prevost bushing may look like the DMC the design is not as well thought out as the DMC. If you have any flex with the Prevost bushing it will crack the flange right off as it is not supported. DMC machines the gears so the flange on his bushing is also press fit into the gear.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
PM SidewinderBob, he helped me out a couple years ago. Not sure what is was made but it is longer than stock. It is still perfect after 5000 miles. He told me he doesn’t usually sell them or advertise but helped me out cause I wanted it ASAP and was from TY. Great guy and very knowledgeable also had a garage full of winders.
DMCTurbo
- Nov 12, 2005
Justin is a personal friend and hasn't had any failures reported to him with hundreds of bushings out there.While the Prevost bushing may look like the DMC the design is not as well thought out as the DMC. If you have any flex with the Prevost bushing it will crack the flange right off as it is not supported. DMC machines the gears so the flange on his bushing is also press fit into the gear.
DMCTurbo
- Nov 12, 2005
Bushing alone.$120.00 for the bushing alone? Or is this a new gear setup with a replaceable bushing?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Hurricane Roller Bearing ProCross Upper Gears - Hurricane Performance
The ProCross chassis commonly needs upper chain-case gear replacement due to bushing failure. This Bushing failure can cause catastrophic chain-case failure if not caught in time. The Hurricane Roller Bearing Gear is a new gear with the bushing replaced by a roller bearing. This creates long...
Prevostperformance
- Oct 27, 2021
- Chelmsford ontario
- Sidewinder
Thanks for the post, however we have yet to have a failure that I’m aware of. My replacement bushing is different than the dmc design and I’m really not sure what material he uses or how he installs them. There’s no question the dmc setup is a great product they have lots of happy customers. There’s many others making gear bushings at this time maybe one of those have failed? Please don’t rope me or my products into it. Even if the rear flange of the bushing cracked off (which hasn’t happened) it would act as a spacer and still work just fine as the material I use is very good. I use a a steel spacer instead of just bushing material riding up against the snap ring. There’s many great options out there hurricane had a great idea with a needle bearing that is working well from what I have heard aswell. There’s lots of pie for everyone.While the Prevost bushing may look like the DMC the design is not as well thought out as the DMC. If you have any flex with the Prevost bushing it will crack the flange right off as it is not supported. DMC machines the gears so the flange on his bushing is also press fit into the gear.
Crossfire12
- Feb 13, 2017
Just stop the wobble,
RobX-1
- Coldwater, OH
If @Prevostperformance is going to be posting on this forum and advertising/promoting their products, maybe they should also become a paid advertiser like Hurricane and others.
Prevostperformance
- Oct 27, 2021
- Sidewinder
Not advertising or promoting, answering a negative post regarding my product however I may look into becoming a paid advertiserIf @Prevostperformance is going to be posting on this forum and advertising/promoting their products, maybe they should also become a paid advertiser like Hurricane and others.
Mototown
- Sep 11, 2018
- Apex 40 th
Have made my own set up with bushing and spacer , I have fine tune the set up so there is almost no wear ( oil is still clean also ) . you find a good machinist , he will point to problems of each gear set up , all of which are better than stock ,
- 31K
