Turbo Dynamics Canada Dyno results
Can you tell us if local dealers for you will have the flashes available and how they are actually installed. What hardware? Thanks
Current TD dealers will need a new cable. As of now all flashes will be done directly at TD.
But we hope to have dealer cables and dealer software ready by 1st week of December.
Thats Awesome! My dealer is one of your dealers so just more convenient to keep it local.
So is this making as much power as the Super Quiet?
No... We dont have a dyno run with the Super quiet and the final version of td ecotrail flash.
We made some changes to the super quiet model and the sled is ready to run Monday.
I estimate the new Super quiet to be 124 to 125 at the track.
thanks keep us informed, and get a DB reading while you're at it, you can get an app for your IPHONE' at least a comparo in the same room on the dyno would be nice or outside, stock vs other mufflers..thanksTD
We have a db meter.
Quietest is td stock modified followed by super quiet than turbo force is significantly louder then a straight pipe is significantly louder than a turbo force
How many feet do you want the test at?
We have a db meter.
Not to butt into the thread but 13.5 feet would be a good distance.
That's the standard in some states - 13.5 feet at idle. 88db is WI..
50 feet also... I believe super quiet will pass all of these as well as stock modified.
We'll keep you up to date.
I'm freaking out on this motor... starting to be hard to hold out until 2018... but i'm still waiting.. its getting hard...:yam:
If this is about $'s I can understand.
But why wait until a SW blows by you on the trail , or lake ,or back road , or the hydro lines , or ??????????
And then you go and get one .
its a little about $$ and also about 1st year didn't have good experience in the past with first year production, second year bugs are out and fixes are known so you don't have to do the R&D all winter..
were your 1st year production issues on Yamaha sleds ?
last year i bought 2 2016 sleds...yamaha with the single shot...that lasted 200 kms.. then a zr8000 wich was quite ok, but clutchs (1st year with team) where pathetic.... that's just last year...
Does the flash and hi flow exhaust require a high flow air filter? In the motorcycle world u normally add a high flow air filter to go with a hi flow exhaust and tune. Just curious...
No... All testing is with stock air filter. Only the mods mentioned are used.
Exhaust and tune... That's it.
