Can you tell us if local dealers for you will have the flashes available and how they are actually installed. What hardware? Thanks
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Current TD dealers will need a new cable. As of now all flashes will be done directly at TD.Can you tell us if local dealers for you will have the flashes available and how they are actually installed. What hardware? Thanks
But we hope to have dealer cables and dealer software ready by 1st week of December.
Thats Awesome! My dealer is one of your dealers so just more convenient to keep it local.Current TD dealers will need a new cable. As of now all flashes will be done directly at TD.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
So is this making as much power as the Super Quiet?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
No... We dont have a dyno run with the Super quiet and the final version of td ecotrail flash.So is this making as much power as the Super Quiet?
We made some changes to the super quiet model and the sled is ready to run Monday.
I estimate the new Super quiet to be 124 to 125 at the track.
super_rash
- Feb 24, 2014
thanks keep us informed, and get a DB reading while you're at it, you can get an app for your IPHONE' at least a comparo in the same room on the dyno would be nice or outside, stock vs other mufflers..thanksTD
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
We have a db meter.thanks keep us informed, and get a DB reading while you're at it, you can get an app for your IPHONE' at least a comparo in the same room on the dyno would be nice or outside, stock vs other mufflers..thanksTD
Quietest is td stock modified followed by super quiet than turbo force is significantly louder then a straight pipe is significantly louder than a turbo force
How many feet do you want the test at?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not to butt into the thread but 13.5 feet would be a good distance.We have a db meter.
That's the standard in some states - 13.5 feet at idle. 88db is WI..
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
50 feet also... I believe super quiet will pass all of these as well as stock modified.Not to butt into the thread but 13.5 feet would be a good distance.
We'll keep you up to date.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
If this is about $'s I can understand.I'm freaking out on this motor... starting to be hard to hold out until 2018... but i'm still waiting.. its getting hard...![]()
But why wait until a SW blows by you on the trail , or lake ,or back road , or the hydro lines , or ??????????
And then you go and get one .
super_rash
- Feb 24, 2014
its a little about $$ and also about 1st year didn't have good experience in the past with first year production, second year bugs are out and fixes are known so you don't have to do the R&D all winter..
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
were your 1st year production issues on Yamaha sleds ?its a little about $$ and also about 1st year didn't have good experience in the past with first year production, second year bugs are out and fixes are known so you don't have to do the R&D all winter..
super_rash
- Feb 24, 2014
last year i bought 2 2016 sleds...yamaha with the single shot...that lasted 200 kms.. then a zr8000 wich was quite ok, but clutchs (1st year with team) where pathetic.... that's just last year...
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Does the flash and hi flow exhaust require a high flow air filter? In the motorcycle world u normally add a high flow air filter to go with a hi flow exhaust and tune. Just curious...
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
No... All testing is with stock air filter. Only the mods mentioned are used.Does the flash and hi flow exhaust require a high flow air filter? In the motorcycle world u normally add a high flow air filter to go with a hi flow exhaust and tune. Just curious...
Exhaust and tune... That's it.
- 7K
