SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
I would guess the guy who had it should never have owned it. I have a bud that put 10000 miles on his winder in 2 years and had almost no issues.
I hope to be like your bud going forward, lots of miles, smiles and no problems.
I hear ya!! Getting use to going over the winders every year preseason and then we have no problems in the season.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Did you do the BOP wedge?I have done everything on it myself so far. The problem is I bought it this spring and discovered the following.
1. Coolant hose on the right in the tunnel was torn, all the coolant drained out onto my garage floor within 2 weeks of getting it.
Replaced hose and added BOP protectors
2. Reverse shaft in chain case was bent pretty badly. Top gear was also shot after just 1200 miles on the clock.
Replaced shaft and added DMC top gear
3. When I got it the one time I ran the sled it was doing 9500RPM @118 MPH (50F out with very soft snow).
Picked up a TPHH clutch kit at west bend show, will tune it in when we get more snow.
Everything I know of should be fixed but it is what I may have missed that has me a bit leery for the first few trips.
I just find it amusing and frustrating, I got almost 12k miles on my two 2-strokes that were known to be incredibly unreliable sleds (I did rebuild the motor in one) but have already put just as much work into the SW and I have ridden it for 10 miles total.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I have not. I plan to replace the track next summer with a bit taller lug either 1.5" or 1.6" and at that time will either have the current shaft spray welded to an interference fit or if the new shafts are all correctly fit possibly just replace the shaft.
If the sled was brand new I would do it but seeing as the current shaft has already spun if it is going to the BOP wedge won't do much anymore.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
Does anyone have a bed open they would be willing to split the cost of the room on for the Houghton ride?
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I know weather can change in an instant..... but the upcoming up Houghton ride looking sketchy.
Ground/lakes are not even frozen.
I know weather can change in an instant..... but the upcoming up Houghton ride looking sketchy.Ground/lakes are not even frozen.
You are correct, no much for snow and not looking good for the first ride of the year. I am going to give it until the end of next week and then I may have to call it if nothing has changed.
like that all over. brother 1 hr away from me just got 1' + of snow and i can still cut the grass and see open water on the lake behind the house.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
fingers crossed that the lake effect snow machine kicks in high gear next weekend when the canadian cold front moves in. gonna be a bored winter if it dont pick up for once got all farm work done early to enjoy winterlike that all over. brother 1 hr away from me just got 1' + of snow and i can still cut the grass and see open water on the lake behind the house.
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
We
went riding dirt bikes last weekend. Lol.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Was holding off till April to get my 2021 X4 XTR, if this keeps up may go ahead and get now.....
I would rather be doing this
until April 1
Was holding off till April to get my 2021 X4 XTR, if this keeps up may go ahead and get now.....I would rather be doing this
until April 1
Right on!!
Eagle1
Hope to see you and boys up in Houghton!! Will be up that weekend also.... hopefully with Nate.
Pattern change coming in week.....keep the faith!!
Pattern change coming in week.....keep the faith!!![]()
We are all hoping!!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
- 11K
- 26K
- 14K
