Yes sir I have.. about 400 miles on so far.. works very well.
12 is intoxicating cannot wait to feel 20#'s!!! just waiting on the call from Allen!!!
And dont even bother using 8
8! I don't need no sticking 8! Actually I use 8 when riding with friends on Ski-Don'ts Poorlaries Pro-X 800's and hoverounds cause I don't want them to feel so bad.
Studroes144
- Oct 30, 2013
Tom how high have u pushed the boost on it? Thinking I'm gonna just pull my thick head gasket out and put in the same thick shim u got and crank it up. I have a pc5 pti, ignition module, rising rate regulator and bigger injectors...only thing missing is to lower the compression way down and crank it up.
I am running 12.5 to 13 and with no problems... she pulls hard too.
Studroes144
- Oct 30, 2013
Just trying to understand the process with the cams when using your thick head shim. You simply adjust both cams one link on the chain and that's all that needs to be done there to correct the difference with the shim?
Thats what I understand. Ulmer made the changes.. so maybe contact him and buy the gasket from him and he can clarify.
Studroes144
- Oct 30, 2013
Thanks Tom, gonna shoot him an email right now. Not much of a good outlook for snow right now and sled is apart anyways, mights well crank it up.
Heck ya!!
Stud I can tell you my 15 with stock motor is making a lot more HP at 7 & 10.5 than my 14 with 9 & 13. Even with taller gears it it has harder acceleration than the 14 and I have hit 114 on snow at 7 and not even WOT whereas the 14 at 13#'s on ICE track with 21/41 gears never did any better than 112. run pump gas at 7 and race at 10.5 which I have not done yet bcause I am still in break in but next week I will.
- 14K
- 23K
- 8K
