Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
If really,really needed I will remove one of my bolts and measure it all up for you but if not available from Cat they must be available from Yamaha. Here is all the good stuff. Let me know if you need measurments of bolts.
Here is complete RR shaft. Stronger bigger design. Those bushings on end are same dimensions other than the flange is thinner. They also are machined rather than powdered metal like stockers. I would imagine the RTX LE is same thing. Didnt have one on hand to check so all I have are Cat part #'s
8408-051=Bolts 2 needed
3604-791=Bushing 2 needed
3604-711=Front Arm axle 1 needed
3604-798=Center Shock Axle steel 1 needed
These are what I believe are the equivalent Yamaha Parts
8KN-G7465-00-00 = FRONT ARM AXLE 1 NEEDED
8KN-RA1A0-00-00 = BOLTS 2 NEEDED
8KN-RA805-00-00 = BUSHING 2 NEEDED
8KN-RA729-00-00 = CENTER SHOCK AXLE STEEL 1 NEEDED
Cannondale where can I get the Yamaha parts you have listed here for a reasonable price? I tried to look them up at Babbitsonline but they do not have a part number search.
Try Port.Cannondale where can I get the Yamaha parts you have listed here for a reasonable price? I tried to look them up at Babbitsonline but they do not have a part number search.
rbell14
I called babbits and was able to get all the RR parts. In some instances the Yamaha part was more expensive than the Cat part and in some instances the Yamaha part was out of stock but I could get the cat part.
Port is fine too, just be prepared for same scenario on cost and availability.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I will be now offering a reinforcement kit for the tunnels. See link in sidewinder forum.
https://ty4stroke.com/threads/barn-...nforce-the-front-skid-mount-in-tunnel.153861/
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
So, just to clarify. Does the 2016 LTX-"LE" have the good upper and lower cross shaft or not?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
No it doesn't! I upgraded last year but no damage yet. Figured I better upgrade ahead of timeSo, just to clarify. Does the 2016 LTX-"LE" have the good upper and lower cross shaft or not?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Best way to verify is to take a 5/8" wrench. If the open end of the wrench fits over the shaft you have the std cross shaft.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
If a upgrade is needed did you come up with a aftermarket option ? ( not the cat RR parts)Best way to verify is to take a 5/8" wrench. If the open end of the wrench fits over the shaft you have the std cross shaft.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Tring to do the same... upgrade to not have a story to tell and (^@+_ up chassis.No it doesn't! I upgraded last year but no damage yet. Figured I better upgrade ahead of time
- 47K
