Dimebag
Installed subframe, electrical harness, steering post, hooked up all gauges,
installed new drivers. It was a good day.
LLCCD69
Got the yammis ready to go Rebuilding a polaris 600 engine i dunno who worked on it before but its a mess. Cant complain got it for nuthin i will let someone i dont like ride it just kiddin
Attak
Replaced front bushings from Pioneer
Cleaned and greased
shaper bars
charged battery
Vmax 600 DLX
new slides and screws
replaced one rear wheel and greased the skid
new trail arm and powder coat both trail arms
red running board inserts
greased clutch bearings
cleaned and detailed
shaper bars
aligned the skis
changed chain case oil
replaced two bearings in the skid
newer snow flap and strap
shock covers and windshield bag
charged battery
Cleaned and greased
shaper bars
charged battery
Vmax 600 DLX
shaper bars
aligned the skis
charged battery
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
Got powdercoated parts installed and finished shining the tunnel! Waiting for snow! (Sorry about picture quality not the best)
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
I looked at my sled... BUT THE SNOW IS FALLING!!!
hearnoevil
newfie09xtx said:Got powdercoated parts installed and finished shining the tunnel! Waiting for snow! (Sorry about picture quality not the best)
Looks great, how much did it cost?
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
He was running a grand opening deal where powdercoating was 50% off. For Front bumper, A arms, spindles, rear bumper, and hand guard brakets cost $100. Regular pricing wouldve cost $200. They do excellent work.
As for the tunnel polishing, cost ALOT of patience but well worth it in the end!
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
BombaPolaYama
Very nice colour scheme!Leno said:pics of my phazer that was just finished this weekend
BombaPolaYama
Raining here on Sunday so I couldn't take it anymore and started up the VLite. It started fine and ran for 10 seconds and shut off. I had a tough time getting it going again after letting it sit for 5mins and wouldn't start w/o giving her some throttle as it seemed to be flooded somewhat. Was uneasy about doing that on a 4-stroke as I've heard it can foul the plugs and I only have 15,954Kms on mine!
Finally it ran good but it seemed to take a long time for it to drop down to normal idle. Started again about an hour later and it ran well but again seemed to stay around 2500 RPM for longer than usual - maybe I'm forgettting how long they usually take to drop down to ~1700. Any thoughts on any of this? BTW, I did use fuel stabilizer before storage but it is the first year that I didn't start her up in the summer. Would there be any problem with running some automotive fuel system cleaner in the Yammie?
thanks,
thanks,
Supa Dexta
No issue^.. But a lot of guys always do this, they get anxious to run their sled, its the first time of the year, its sat a while, the fuel is old - even with stabilizer - and they panic something is wrong.. Just wait to give it a proper ride and get fresh gas in it again, I'm sure its fine.
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
I had stabilizer in mine but when I start my it takes 3 times before it will idle. I expect old gas is the problem with mine as well.
BombaPolaYama
Thanks for the reassurance. Not sure if you meant there would also be no issue with using the fuel system cleaner or not. I'm thinking it should be fine to use as I've used it in my outboard with good success.Supa Dexta said:No issue^.. But a lot of guys always do this, they get anxious to run their sled, its the first time of the year, its sat a while, the fuel is old - even with stabilizer - and they panic something is wrong.. Just wait to give it a proper ride and get fresh gas in it again, I'm sure its fine.
Supa Dexta
Yes, no issue with the cleaner, but use as directed.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Pulled my chain case apart for the first time. I gotta say it was a piece of cake after the problems my fathers' AC chain case gave me. Going to change out the bearings and maybe put in a new track.
