STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Defiantly quicker, smoother. I cant say about top end as I have to yet have it to top speed.Stain,
Great info here and thanks for sharing.
Can you attest to any performance gains with these clutches such as faster et, topend etc???
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Stain,
If your clutching setup is correct with the stock clutches, there will be no performance gain in going to the TAPP clutch or any other clutch.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I have to disagree. I could not get the stock clutch to upshift as aggressively while maintaining proper belt squeeze as the TAPP. It pulls harder off the bottom than any other stock set up I tried EXCEPT Heelclicker Draggin Flies. It seems similar to those weights.If your clutching setup is correct with the stock clutches, there will be no performance gain in going to the TAPP clutch or any other clutch.
Top speed, I will agree.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Definitely better on take off, acceleration, top end shifts right out depending on gearing.just saying
WinterWolf
- Mar 25, 2017
- Connecticut
Well that’s just it....nobody can seem to get the set up correct, and keep all the other parameters in check as well! So with JUST that being said Alone...I think the TAPP will out perform the stock clutch all day long. And last a whole hell of a lot longer doing so...
Also it’s a 4 arm High performance Billet aluminum clutch...meant to deliver outstanding belt squeeze and very aggressive shifting....how could that alone not work better than the stock primary?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I think reliability is probably the number one improvement, number two will be the improved belt tension down low. The 43 start angle on the STM or Pro4 secondary is super responsive. I ran a 44 start angle and loved it but I needed a bit more weight down low, but my weights were full in the heel.
Tcat100
The real world acceleration improvement is significant. A flyweight style clutch struggles to match the belt squeeze the Tapp easily achieves. It's just geometry and physics...maybe some engineer here can prove it on paper, but the real world difference is big.
Crossfire12
- Feb 13, 2017
Conditions are different everyday, if your anal, you can adjust on trail side simply by changing clicker position.
WinterWolf
- Mar 25, 2017
- Connecticut
And this was my point...good post. Real world is where we ride!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea I really like those clickers for quick adjustment on my old Ski-Doo!
Anal reminds me to much of running down dirty trails, too much scratchy goin on if yer girls been eating corn nuts.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
I just got my TAPP yesterday. For you corner-to-corner blasting, 0-100 mph-matters-most guys, what are your setups with the clickers (what number?), ramps (A or B?), and weights? I'm not worried about top-end. Thanks.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Quietest clutch I've ever heard. Thing doesn't make a peep! Now just need my Pro 4 from Tom at Tommcat and we'll be good to go.
sledding rocks
what belt is r u using with the Tapp and pro 4 ?PRO4 is in. Stock bolt doesn't work in adjuster. Choice was to either lathe down the flange, and find a socket to fit in the adjuster, or go with a Socket head bolt. OFFSET is at 59.1 mm ( still curious as to what others are at to compare ) Engagement is right around 3600View attachment 152042
sledding rocks
well just ordered my Tapp also . boy my wife is going to kill me
Tcat100
just tell her it's man jewelrywell just ordered my Tapp also . boy my wife is going to kill me
