ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Cause what most of the time?
High RPM’s ?
Low RPM’s?
Both?
Just noise?
Symptoms in general?
Your experience and thoughts?
Especially pertaining to this new Sidewinder roller?
High RPM’s ?
Low RPM’s?
Both?
Just noise?
I get a weird Vibration at about 40 mph and 60 mph almost like a bearing and the clutch rattles louder then normal. Sorry I thought this was for rollers.. not sure on secondary bushing.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
High RPM’s ?
Low RPM’s?
Both?
Just noise?
I've never experienced worn secondary bushings, if its like the primary the RPM would be low, however its the driven, and maybe then it would bind not allowing shift out and RPM would be higher and perhaps blowing belts.
Who has worn secondary bushing?
One thing to note. The secondary needs bolted together to see the movement, slop or bind. You can't just check the movable on he shaft alone as it will always wobble on that short bushing. There has to be enough clearance that when it heats up it does not bind and stock to the shaft and not slide easily.
True, I've seen many people assume they have sloppy bushings until I tell them to bolt it together without the springs and then check.I've never experienced worn secondary bushings, if its like the primary the RPM would be low, however its the driven, and maybe then it would bind not allowing shift out and RPM would be higher and perhaps blowing belts.
One sign of worn bushings is the surface coating worn off.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
this happened on my STM secondary. Bushing felt ok, but once I installed a $10 new one I saw how much tighter it was. Vibration gone.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Vibration I had a cat with the older roller secondary, when the center bushing wore I had bad vibration, I didn’t know what it was until one of the sheaves started to wobble, way bad, had to drive back slow, when I put on stand you could see it.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Thanks guys lots of good replies. John the Frenchman was wondering why his rpm’s were lower after replacing his bushings.
I’ve seen high rpm’s on an old ski-doos button secondary. The bushing on the helix was so worn that it wouldn’t shift out properly.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I have had my engine bog down on my nytro while accelerating at 70 mph. Worn secondary bushing would cause my secondary to bind. After replacing bushing the bog went away.
On the sidewinder it could just snap the belt if it binds.
- 22K
- 6K
- 55K
