SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
- 2017 Sidewinder ltx dx
O.k. so I removed my suspension to replace all the wheels and rebuild my shocks. After putting it all back together I loaded it on the trailer and noticed it didn't want to compress all the way down. The suspension and rear shock moves until it hits the couplers then wont compress any further unless I loosen the track. Frustrated, I left it with a dealer for three weeks and they couldn't find the problem. If track tension is set as recommended it seems to push the suspension back rather than collapse?? Dealers recommendation was to reach out to you all for help.
HELP!!!
HELP!!!
earthling
Unless your suspension is flat on the floor you will not be able to compress it past the coupling blocks. Pushing down on the rear is not how the suspension works. The suspension is an approximation of a parallelogram, it wants to move back and up at the same time, when you push down on the back you are simulating weight transfer which will run into the couplers and act just as you describe. When you loosen the track you are giving the skid the ability to move backwards just enough to rotate around the pivot that is locking you out. This is never a problem when the sled is in motion. If your dealer cannot figure out how to get your suspension articulation back, you should go get your sled and never go back there again.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Dealers rec was to check TY? Wow.
SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
Than
Thank you! I did pick it up and bring it home. Flat on the garage floor it would not compress with a 350lb man laying across it. Back at it Monday myself
SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Are you certain the rear shock is installed correctly?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
THIS is what I was wondering? like the shock is upside down and the res is hitting?Are you certain the rear shock is installed correctly?
SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
It has a Q3 on the rear. Everything is exactly the same as my viper sitting right next to it.Are you certain the rear shock is installed correctly?
DennyTuna
- Jan 28, 2017
- Ohio
Where the shock attaches towards the front of the skid is that arm in the up position or is it down?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
a picture of the skid will help usIt has a Q3 on the rear. Everything is exactly the same as my viper sitting right next to it.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I was thinking the same thing because it flipped on me one time and it was acting the same way.
Elton Buss
I would take the shock out of the skid and see if you can compress it. I had shocks for an Arctic cat rebuilt years ago and had the same problem. When the shock was rebuilt it was put back together wrong and would not compress. The company redid the shock and worked when I got it back.
joe243
- Feb 1, 2012
SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
Thanks, think thats where I'm gonna start.I would take the shock out of the skid and see if you can compress it. I had shocks for an Arctic cat rebuilt years ago and had the same problem. When the shock was rebuilt it was put back together wrong and would not compress. The company redid the shock and worked when I got it back.
SaddleBagger
- Mar 28, 2018
- Fenton, Michigan
Yes, the ears are upright. Did that also years ago, lolYour sure your shock is installed right. The lower dog lag it ahead like in my photo. I’ve seen installed with the shock back closer to the track. It’s an easy mistake while the skid is out
- 6K
