ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Its more then 1/8".. I would guess 3.5mm would be about perfect(approx 9/64)You can only cut about an 1/8” off Before the shaft disappears into the secondary bushing
I took of 4mm, and im .5mm over.....but I have custom shims.
Dan
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So, who does one go to to get the machine work done?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
machinist.....Its a basic job for them.
Just take secondart apart, and be sure to mark the BACK side hub, and I measured mine and told him what to cut it down to.
I took off 4mm......which is abit past flush and then had custom shims made so I can do alot with my offset. I did not want to have the hub directly against circlip. And you need to be careful so full shift does not hit frame(bearing bracket)
So I would recommend 3.5 mm removed so you are not past flush.(at full shift)
Best thing would be to take it apart, take it to machinist, mock it up without spring with just helix and one nut tightened down in front of him so he understands the way it works, and then show him that you dont want it to go past flush when at full shift after being cut. Meaning the movable sheave only opens as far as FLUSH with the newly cut down hub.
Dan
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
It’s such an easy machining job it will literally take 10 minutes. Google machine shops in your area, go to a small one because the larger machine shops will roll their eyes at such a small job, they don’t generally like taking smaller jobs.So, who does one go to to get the machine work done?
Doc Harley
- Oct 17, 2016
- Here & there
I will check mine in the next couple of weeks. To see how far off I am. More of a preventative maintenance item so when things get turned up.
Thanks guys!
Thanks guys!
NYTurbo
Anyone check offset on the cat clutches ?
Guys around here have 3000 plus miles on same belt and your not hearing many issues with them.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Are you talking about the two on heat exchanger right? And the two on the front mount bracket,you would have to remove material from all 4 points,egg shap them I guess,myself I would not,and its a major job to get all 4 points elongated out. Best of luck.On the engine you have 2 pieces of engine mounts mounted with 2 bolts each. If you remove the engine mounts from the engine you can remove some materials from the backside of the engine mounts.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Diff clutches so they would have their own sweet spot. Likely completely diff then ours as they may measure them diff then we do and obviously diff sheaves are diff thicknesses ect ect....Anyone check offset on the cat clutches ?
IMO cat has better belts avail....but others scoff at me for thinking this.lol
Dan
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I think he is referring to the mounts themselves and where they bolt to the motor.
Maybe not? I have not had mine apart like you did Pete, you have seen this model stripped down huh?
NYTurbo
How thick is the yamaha inside Primray Sheave at the top ?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Blew 2 more belts at.......................you guessed it......................900 miles
I own THE most consistent Sidewinder of all. I mean it's within 50 miles or so. Amazing.
I'm happy that i have so many 900 mile belts blown because that means i have over 6000 miles.
I've learned from SOUPY to just enjoy life & make lemonade out of lemons..........I should have opened a lemonade stand!
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
2 more belts last wknd, up to 18 now. Your lemon's not a lemon, especially if you REALLY ride the thing!
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Did you get any better belt life?
Soupy
- Jan 10, 2017
- West Michigan
Is that a joke? 2 belts in 2 days!??!
OK, DON"T shoot the messenger. I stopped by a Yamaha dealer on the way to the cottage Saturday to discuss pricing on the upcoming 2019 SRX. Talked with their service tech to discuss the issues he has seen on the Sidewinder series. He also indicated that the Yamaha rep that reviewed the upcoming 2019 models with him/dealership advised that there are revisions coming from Yamaha for clutching. Specifics were NOT given at that time so we will have to wait and see if info is available at the upcoming "sneak peek".
- 40K
- 14K
