ShootToThrill
No I was looking for primary
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
This is a thread I started that has some good info....No I was looking for primary
http://ty4stroke.com/threads/stock-primary-spring-rate.147090/
Dan
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Been doing a lot of reading on the clutching. I found most of the most useful info is in the sticky FAQ thread. Your spring rate thread should go in there as well. I also stumbled on some YouTubes from Nos-pro (I think) that helped a lot with seeing the clutches taken apart and serviced.This is a thread I started that has some good info....
Dan
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
Where can I get the glide washers?
fourload
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
So TP’s orange secondary spring is junk?? Nice.If you are asking about secondary spring......No, I have tested every spring, Red/White Cat spring and even custom springs.....I keep going back to the stock secondary spring. Results are huge loss of top end charge and mph....
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Shagnos. The post you quoted is from last February before we designed the orange spring and the reason we designed the orange spring. Please watch dates as some topics have been going for a long time. We made a new spring because there was not one currently made that would work. The orange spring rocks. Don’t worry your all good if your running it.
Sent from my iPad using Tapatalk
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Sorry, did not look at the date. I have the orange spring.Shagnos. The post you quoted is from last February before we designed the orange spring and the reason we designed the orange spring. Please watch dates as some topics have been going for a long time. We made a new spring because there was not one currently made that would work. The orange spring rocks. Don’t worry your all good if your running it.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Orange out back seems to be the ticket for boosted applications. No coil bind and prevents belt slip.
- 11K
