shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
With that kind of HP what's the setup for the orange secondary spring? Which holes?
6-1.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
6-1.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
My thinking was that I'm having secondary and primary spring binding issues, so I wanted those as part of the kit. Thought running a complete kit from one company would be easier to work with.i don't no why you guys don't run the hurricane weights
Sent from my SM-N950U using Tapatalk
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Thanks Shagman. I must say, that's a little disappointing. I was under the understanding that if I provided all my info when ordering (riding weight, sled, modifications, and tunes I'd be running) that the weights would be set up to a good starting point for me....or at least include all the parts I needed. I guess not, looks like I was shipped weights set up for a stock winder then.For that much hp you will need 7/16 or 1/2 brass in the tip. Call Lonn and he will get you what you need. They are not in the kit. The 7/16 weighs 7.2g and the 1/2 weighs 9.2g. I run the 7/16 on asphalt at 280ish. 17.5# boost TD flash.
shagman
Vendor
- Feb 18, 2014
Do you know how much boost that tune is.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Reviving this thread again as there's a ton of useful info here. Would be great for guys to post their ecu tuning, clutching, and weight setups here to help everyone else with tuning their clutches.
I have a thunder products kit with heavy hitters, setup the way they were sent to me. I'll be running Hurricane's 270 and 280 race flashes with CAI, I'm 230 lbs fully dressed. Heavy hitters with 58 g base weight have 7/16" steel bolt and thick washer (5.6 grams) in tips, 3/8" steel bolt in mid hole (2.6 grams) and 3/4" slug in heel (3.3 grams). I'm wondering if I should add anything to this before I install the kit. Anyone have any experience with the kit and similar tuning and can provide input for me?
Ad a thick washer to the mid and try it. It should be close I don’t think it will be that far off
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
My max pump 285hp setup was 3/4 heel 3/8 with thick mid and 7/16 with 1 thick and 1 thin tip
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Thank you Dieselxtx. I spoke with Shagman on the phone today and discussed the setup, and he agreed that I would be close and could just add a second thick washer to the tip and see where the rpm's end up. Very happy to hear I will be close. I got concerned when it was mentioned I would need a bunch of different heavier bolts to try as I wanted to experiment hopefully this weekend. We just got 8 inches of snow today.
- Apr 14, 2003
- Hessel, Michigan
Have the same weights and running EVO's stage 4 tune. My weights are 3/4 allen in the heel, nothing in the middle and 7/16 with 2 large washers in the tip. Rpm's were 9,000
If you add 1 more thick washer to the tip, I believe you will be spot on with 3/8 in middle, 3/4 allen in heel and 7/16 with 2 thick washers in the tip.
Jafo1970
I went from the evo tune to the hurricane 280 race. I have the heavy hitters in base 58 also. Yesterday I tried 3/4 and 1/4 slug in base, 7/16 steel with 2 thin in mid and same in tip and was over revving too 9200, so need to add tip weight. If that helps you. I'm shooting for 8900 rpms. I did get some of the thick headed brass bolts from Lonn.
- Apr 14, 2003
- Hessel, Michigan
Jafo - What were your rpms through the range? You might want to just put 2 thick washers added to the tip instead of the 2 thin washers. That will bring you down 300 rpms.
8,800 -8,950 -9200? (stabbing throttle down low to top speed)
Jafo1970
It will hit 8900 and then go to 9200. I was going to throw a 7/16 big boy brass in tip at 7 grams. I think doing the two thick washers instead of 2 thin would yield the same also. I was going to move my helix to 6-1 also, it's at 3-3 with Lonn's orange secondary spring. I ran 6-1 last year and like it. I move it to 3-3 this year on Lonn's advice but lost a little snap. Not sure how much rpm it will raise going from 3-3 to 6-1 does?Jafo - What were your rpms through the range? You might want to just put 2 thick washers added to the tip instead of the 2 thin washers. That will bring you down 300 rpms.
saskattakman
for the guys running an extra 1/4" in heel as well as the 3/4" is that more so for short tracks or everybody?
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Shagman told me not to bother with the extra 1/4 in the heel, that due to where the extra weight ends up it doesn't end up doing anything for you.for the guys running an extra 1/4" in heel as well as the 3/4" is that more so for short tracks or everybody?
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Thanks a lot guys, this is exactly the dialogue I was hoping for.
