Jafo1970
I love my 35/39 helix. Holds rpm really good. I'm a shorty also. Running TP primary spring and there secondary spring. I tried a 38 straight and didn't care for it.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
what did you not like about it? I have one from STM my boy last year ran with a cat secondary spring,but we wrapped it to tight,and it slipped out of hlix hole and was chewing up the inside spring land of the helix,but with loans orange spring I would give it another try,if I thought it would work ok.I love my 35/39 helix. Holds rpm really good. I'm a shorty also. Running TP primary spring and there secondary spring. I tried a 38 straight and didn't care for it.
Jafo1970
I tried it last year so if I remember right it struggled in the mid range with rpm and took a little longer to reach peak rpms. The 35/39 was snappier and better cruising rpm and better mpg. The 38 was a STM and my 35/39 is a Dalton also.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks Jafo1970,right now,i changed things around some,so primary loaded with STM supertips to 80 grms,same as last year,but loans orange primary,i did try dales blk/green,to much engagement,and I still yet have his blue/blk to try later,ok back to clutching 2017 lol secondary now stock 35 loans orange at 3&3 with stock 8jp belt from last year,with 720 miles on,and still looks very good,all I have is engagement 3000 cant open up yet,so hoping for 9150 shifted for my stage 4 tune and CAI,22/41 geared so we will see how this shakes out.I tried it last year so if I remember right it struggled in the mid range with rpm and took a little longer to reach peak rpms. The 35/39 was snappier and better cruising rpm and better mpg. The 38 was a STM and my 35/39 is a Dalton also.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Tim and Terry, any clutching updates from your ride/testing last weekend?
- Apr 14, 2003
- Hessel, Michigan
Heavy hitter weight setup was spot on with the new secondary orange spring. Engagement for me was 2,650 - 2,800 with a top rpm of 9,000 - 9,050
Trail to Copper Harbor in sections was nice and flat, speeds up to 128 on the speedo before backing off.
Sled is a monster
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
What did Tim find with Powertrail/orange/orange and the thin washer in the tip?Heavy hitter weight setup was spot on with the new secondary orange spring. Engagement for me was 2,650 - 2,800 with a top rpm of 9,000 - 9,050
Sled is a monster
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Waiting to try mine with TP orange secondary wrapped at 3-3.
Already had the TP clutch kit and 35/39 in it last season wrapped at 6-1. Rpms would be 8700-9000 at first grab, but settled down to 8500. Was told this was a little low and should take tip weight out. Am assuming I should try it again with the new secondary spring before actually messing with the weights, though now?
krm
- Apr 22, 2016
- ny
Ditch the 39 finish .Waiting to try mine with TP orange secondary wrapped at 3-3.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Here is the setup.
Orange primary spring.
58g base weight
Tip 7/16 steel bolt with thick washer
Mid 3/8 steel bolt
Heel 3/4 set screw
Secondary
Orange spring set 3-3
8900-9000 rpm
Gates carbon belt in 8jp length.
Sled is a BTX LE with 2 1/4 track with 26/48 gearing.
Several runs over 120 mph on groomed snow.
Sent from my iPad using Tapatalk
krm
- Apr 22, 2016
- ny
Approx 70.3 gm ???Here is the setup.
58g base weight
Mid 3/8 steel bolt
Heel 3/4 set screw
Secondary
8900-9000 rpm
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
Uh, ok. But why? There's a few members here who happen to like the 35/39 and recommended it to me. What don't you like about it and what would you recommend for me? Other than the clutching, I'm stock (no tune.)Ditch the 39 finish .
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Shagman, thanks!Here is the setup.
58g base weight
Mid 3/8 steel bolt
Heel 3/4 set screw
Secondary
8900-9000 rpm
krm
- Apr 22, 2016
- ny
Your under reving .Get the 33/35Uh, ok. But why? There's a few members here who happen to like the 35/39 and recommended it to me. What don't you like about it and what would you recommend for me? Other than the clutching, I'm stock (no tune.)
shagman
Vendor
- Feb 18, 2014
Approx 70.3 gm ???
Yes. Some sled might need a little adjustment from here due to sled length, rider weight, and base weight difference. Base weights are matched up so sets are balanced, but can differ in weight a little. Mine are exactly 58.8g.
