![](/styles/vip.gif)
- Apr 14, 2003
- Hessel, Michigan
- Apr 14, 2003
- Hessel, Michigan
Ryan - I worked on your sled a little last night, and got the track adjusted, and the chain case together. I will take the thermostat out and hook up the quick disconnects this week. Can you get the skis by Thursday?
Everyone - I tested Friday night, and had 2 time runs on Saturday before they called the race due to rain. There might be a great concern from the racers at Wisconsin International Raceway, as there was a street car that put oil all the way down lane 2, and the racers didn't think the track officials cleaned it up enough. When the rain started, a 66-67 Nova with a blown big block, (show quailty remind you), went sideways in lane 2 and hit the guardrail. Coincidence? All I know is alot of people said they should have called the race before this set of cars went down the track.
I will post results from this weekend tonight, as I tried the bottle with 60 horse on Friday night. Right Tyler?
Hey Terry, you yank the thermostat out? I never did last year, does it make any difference? The thermostat is really there to warm the engine up faster at first, once open I don't know if it restricts the flow any more than you quick disconnects. The thermostat should remain open as long as your above the rated temperature, unless it fails, so the only advantage I see in removing it is that it's one less part to fail. Oh yes, less weight too, lol.
So what's this, your moonlighting now by setting up other's sleds for asphalt, lol?
Don
Don
- Apr 14, 2003
- Hessel, Michigan
Don - I took the thermostat out, cause once the cool water hit the thermostat, it would close, and I couldn't circulate the water. The four stroke oil stays hot, and I need to run the cool down longer than the 2 strokes. I am helping Ryan, cause he let me use his SRX suspension for the last 2 years asphalt racing. I at least owe him the help and shop to work on.
O.k., Friday was real weird. Was sunny for a bit, 74 degrees, and then the hail came down. 2 tornados touched down in Fondulac, and big storms everywhere. After 5 pm, the sun came out, and the humidity dropped.
Real Street Drags 5/6/05
1st run was to see if my suspension spring was set good enough.
1.529 60ft. - 6.948 1/8mile @ 94.508mph - 11.245 1/4mile @ 110.341mph
The rest of the runs were done with a 60 horse shot after the 60ft. timer.
2nd run - carried the skis toward the center line, had to lift.
1.590 60ft - 6.588 1/8mile @ 102.401mph - 10.525 1/4mile @ 120.488mph
3rd run - spun off the start line.
1.629 60ft - 6.631 1/8mile @ 102.486mph - 10.634 1/4mile @ 118.826mph
4th run - good 60ft., but ran out of Nitrous.
1.491 60ft - 6.587 1/8mile @ 104.507mph - 10.564 1/4mile @ 117.622mph
5th run - Fresh bottle, but spun off starting line.
1.570 60ft - 6.468 1/8mile @ 106.045mph - 10.212 1/4mile @ 126.531mph
Saturday - 5/7/05 New I wouldn't get any more time runs, I had to see what i would need for a dial-in.
1st time run - Temp 58 degrees, 42% humidity
1.493 60ft. - 6.886 1/8mile @ 96.048mph - 11.140 1/4mile @ 112.150mph
2nd time run - Temp 59 degrees, 35% humidity
1.487 60ft. - 6.909 1/8mile @ 95.293mph - 11.200 1/4mile @ 110.789mph
Races cancelled before 1st round.
yamahajunkie
nos pro5th run - Fresh bottle, but spun off starting line.
get that 60 ft dialed in and your nockin on the nines!!!!
way to go![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
way to go
- Apr 14, 2003
- Hessel, Michigan
Hey junkie - I'm shooting for 9's big time this year!
Remember, this 05 has reverse, stock airbox, stock jetting, trail exhaust, toolbox, and spare belt still on board. Wanted to see if I could do it in trail form. And get it in the 9's with clutching and nitrous.
- Apr 14, 2003
- Hessel, Michigan
Oh, Hell Yes!!!!!!!!!!!!!!!
just got back from the union grove with my trail turbo vector running on pump gas with higher boost. ran a 9.80 at 135.8 mph, ran 115 mph in the 1/8.
- Apr 14, 2003
- Hessel, Michigan
Hey Jeff - Nice going!
? for you, Did they resurface the track? I kind of heard from someone they did, and they needed to get some rubber put down, to make it hook better. I was going to come down last Wednesday, but had plans.
JEFF, THATS FLYING ON TOPEND!!! WHAT WERE YOUR 60FT WITH THAT KIND OF MPH??
________
NEW MEXICO MEDICAL MARIJUANA
________
HyperMax
Good run Jeff. I guess I'll have to come up one of these Tue nights and watch.
Scott
Scott
Right on Jeff, with a Trail Turbo Vector hey? What kind of boost were you running? Man those things fly with the turbos!
Well, looks like we're heading down to Interstate Dragways this weekend for our first run on the tar this year. Hope the weather cooperates!! Can't wait!
yamahajunkie
hey nos-pro is that clutching out of a box (kit) or something you came up with yourself? just asking cause a good track clutch is a good snow clutch. thanks junkie
yamajunkie,the clutching is something throwin together.
- 12K
- 40K
