jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Good to hear..I installed the latest BOP lower driveshaft repair at the start of the season with no issues.My shaft was the original with 7400 miles ,and saved me a bunch of time and labor by putting this on my lower shaft.Travis has a great repair here.This will get me to my next sled after 1/2 more seasons
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
I bought this awhile back and am hoping to install it this weekend before putting the sled away.
Maybe it's obvious once
I bought this back in January and am hoping to install it this weekend before putting the sled away.
Maybe it's obvious once you get working on it - but is putting the set screws in the last step once you put everything back together? Without looking at it I'm thinking you need to put everything together to make sure it's in the right place before putting the loctite on the threads and tightening it.
Just an update on some findings as the season has been progressing. Have now had 4 cases in which set screws came out of the collar. 3 of the cases the collar actually worked itself out of the bearing. I've posted before about checking to make sure your screws have not come loose, but just wanted to stress this again and encourage the use of loctite from here on out for extra measure.
Turboflash
- Mar 18, 2019
- Southern MN
Yes
HABS 1
- Oct 22, 2015
- corunna,ontario
not alot of miles for me this year, being in southern ont, but did get just shy 500 mi on in michigan, without disassembling anything and just doing a visual inspection on a stand with a light, everything looks as good as when i put this bearing in... bearing stayin put in caliper housing, all set screws tight , nuthin movin nuthin loose
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Just did an inspection on this bearing on my own sled after 1 year of riding. Absolutely NO movement on the shaft.
I will be installing another one on my friends brand new Winder this fall before he rides it.
canine170
- Jan 21, 2019
- New York
- 2019 SRX LE
Just finished removing factory bearing from the housing. the bearing seemed fine. I slipped it back onto the shaft and was able to wobble it back & forth. Would this indicate that the shaft is worn and bearing spun?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Sure sounds like it. If you have a micrometer, measure where the bearing sits and use a telescope gauge or bore mic for the ID of the bearing and you'll know for sure. Mine is still snug after 4000+ miles but I prick punch the shaft anyway. BOP bearing is waiting in the wings if it ever shows signs of spinning on the shaft. But wobble? Not good.Just finished removing factory bearing from the housing. the bearing seemed fine. I slipped it back onto the shaft and was able to wobble it back & forth. Would this indicate that the shaft is worn and bearing spun?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Yep. It's spun.Just finished removing factory bearing from the housing. the bearing seemed fine. I slipped it back onto the shaft and was able to wobble it back & forth. Would this indicate that the shaft is worn and bearing spun?
I have 9000 miles on the Barn of Parts shaft expanding original driveshaft saver.
Installed on new shaft & bearings. Torque to 40ftlbs. No spinning. Nice and tight.
Actually was a little difficult removing old & installing new bearing due to close tolerances. Nice!
If yours can wobble, it's surely spun.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
Loose fit condition no good,you made the right choice in the B.O.P. upgradeJust finished removing factory bearing from the housing. the bearing seemed fine. I slipped it back onto the shaft and was able to wobble it back & forth. Would this indicate that the shaft is worn and bearing spun?
canine170
- Jan 21, 2019
- New York
- 2019 SRX LE
Thanks everyone for your replies. I have the BOP bearing in the freezer ready to install today. This page is a great source of information...
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
I'm going to be going through my sled in the next couple days (behind schedule this year but there's little snow anyway). If time permits I'm going to try to install the BOP bearing. It looks fairly straight forward to install but I'm a bit nervous about getting it all together right.
canine170
- Jan 21, 2019
- New York
- 2019 SRX LE
I started my upgrades after finding a list of common sidewinder problems. Thank God I did. The upper gear was bad, the front slider axle was bad, and now the driveshaft worn in from the bearing spinning..
All this on a 2019 Yamaha SRXLE with less than 2000 miles on it. Not exactly quick fixes
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
All those areas are pretty much annual 'checks'. These sleds are capable of logging some good miles, but all these areas need to be checked constantly.
My friend let his upper gear go for 2 seasons, things were so sloppy that the reverse chain appears to have jumped a tooth and got on top of the gear putting stress on it - bending the shaft the reverse gear mounts to. How it didnt crack the housing (that holds the shaft) - I do not know.
Sorry - I am off topic
MS
yamaha06
I installed my Barn of Parts driveshaft bearing this past weekend, install wasn't terrible. The biggest pain was bleeding the brakes since I had to remove the caliper to press the old bearing out. Seems like a great product, previously I was running the wedge and it seemed to work for me but I previously did have the bearing spin on the shaft so I figured I would install this bearing and take the wedge to install on my 23 SRX.
- Feb 13, 2017
- Amston,CT
B.O.P. will be your favorite site for better than o.e.m. UpgradesI started my upgrades after finding a list of common sidewinder problems. Thank God I did. The upper gear was bad, the front slider axle was bad, and now the driveshaft worn in from the bearing spinning..
