ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Gone forever
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well I see we have some votes. If somebody is willing to share what works, or what isn’t working, that may help us draw parallels and figure out what might be going on.
Please try to be as thorough as possible with your setup so we don’t go down any wrong roads.
Thanks, CM
Thanks, CM
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Remeasured my c to c at 261.5. Offset is about 58.5, sure appears by to need less offset to run true.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Anyone care to share their findings?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
LAST YEAR:
-C to C=262mm
-Offset was 61.5mm
-parallel looked good, but i checked with air cleaner on so not 100% positive on accuracy
SNAPPED belt at 900 miles. Shimmed helix & set to 6 & 1.
Did not blow another belt rest of year for another 1600 miles, but no other belt had over 700 miles on it.
-C to C=262mm
-Offset was 61.5mm
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
This year offset is 60.5mm with 2400 miles spread out on 4 different kinds of belts. Blew 1 belt testing. Next week i will be able to put 2000 miles on 1 belt......hopefully
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Any cat guys here? Id like to know the length/width of cat belt....
The week link is belt.....why are there not 1000 belt blowing and alignment threads on HCS? Because they have a hi HP belt avail and we dont.
I know they are wider....so could we use a cat secondary and maybe shim spider to use a cat belt? I think being able to run a cat belt would be a good test.
I dont think we will ever see much over 600 miles per belt with these belts designed for viper HP.
Dan
Dan
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Had some info from a reliable source.....yea he can't give up his contact from Yamaha....
Yamaha has the info they need and are working on a solution for the belt. He didn't think it would happen this season as things move slow.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
263.5 mm center to center
62 mm offset
14xx miles on current belt.
Edit:
Belt snapped in half today. Sounded like a bomb going off!
Blew side panel clean off the sled.
Note to one's self, change belt before 14xx miles on it.
62 mm offset
Edit:
SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
2500 miles of freaking abuse on my stock 8jp.Any cat guys here? Id like to know the length/width of cat belt....
Dan
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
That's AWSOME!
Now can you tell us what the dimensions are or this whole thread is useless.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
62 mm offset
Edit:
I don't mind changing belt at 1500 miles. I just don't want it to EXPLODE before that!
I plan on changing my belt every 1500 miles anyways. That makes 2 belts per year so i'd be at $156 for the year.
That's why these threads are going to help. IF a lot more people chime in...
- 10K
