DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
How many miles does it take to break a new belt in properly? So my thought is during these first agonizing 100 miles to break in the new 50th LTX I would break in a couple of new belts also. Gonna run the 8Jp belts. Run the first one for 50 miles and then put on another new belt for the other 50 miles. Not that this matters but I have the orange secondary spring, HD rollers and Dalton primary spring from TD and a belt adjuster as well. Is 50 miles @ really slow speeds enough for a good break-in?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
look in your yamaha manual it say first 25 mile not more than 3/4 throttle and play with the throttle after that your good to go ...How many miles does it take to break a new belt in properly? So my thought is during these first agonizing 100 miles to break in the new 50th LTX I would break in a couple of new belts also. Gonna run the 8Jp belts. Run the first one for 50 miles and then put on another new belt for the other 50 miles. Not that this matters but I have the orange secondary spring, HD rollers and Dalton primary spring from TD and a belt adjuster as well. Is 50 miles @ really slow speeds enough for a good break-in?
WinterWolf
- Mar 25, 2017
- Connecticut
If you break that LTX in at really slow speeds you're gonna be Real sorry!
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
i must be very lucky. i got on the sled brand new and rode it like i stole it. 3500 miles now on factory belt and no probs yet. thought it was more important to seat the rings than pop a belt.
WinterWolf
- Mar 25, 2017
- Connecticut
Exactly my point!! That's what I'm gonna do with mine too.
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Broke my sled and belt in on Monday. Drove up the field slow for about one mile, then made 6 back to back 1/4 miles passes at wide open throttle, then drove home and let it cool off. On Tuesday checked the sled all over, everything looks good and the sled works awesome. Pulled 110 mph on the speedo in that distance turning 8750 to 8900. Not a measured distance, could be a little longer.
WinterWolf
- Mar 25, 2017
- Connecticut
Sounds great!! Glad to hear she runs great...can't wait to try mine in about a month.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
I was planning the same thing Snoden.How many miles does it take to break a new belt in properly? So my thought is during these first agonizing 100 miles to break in the new 50th LTX I would break in a couple of new belts also. Gonna run the 8Jp belts. Run the first one for 50 miles and then put on another new belt for the other 50 miles. Not that this matters but I have the orange secondary spring, HD rollers and Dalton primary spring from TD and a belt adjuster as well. Is 50 miles @ really slow speeds enough for a good break-in?
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Please explain the theory behind this. I've heard the break it in how you ride it plan but never the science of it. Thanks in advance. Space.If you break that LTX in at really slow speeds you're gonna be Real sorry!
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I read that thing cover to cover, mind must have been wondering while reading that section. Thanks!
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Now that were off topic I'm with Spaceman on this as well. I've read both the Sidewinder and Thundercat manuals and they say this. Sidewinder no more than a quarter throttle for the first 100 miles then no more than half throttle for the next 200 miles. The Thundercat says no more than 6000 rpm for the first 100 miles then no more than 8000 rpms for the next 200 miles. I get seating the rings but, no break-in what so ever?
- Nov 29, 2009
- sabattus, maine
Boost helps rings seat in a hurry. The biggest thing that would need breaking in would be the camshafts. Lots of opinions and stories of I did this and that. If you feel better following the manual by all means follow it. I'm a couple heat cycles then ride it like you stole it kind of guy myself.
As far as the belts go be sure to wash them good in hot soapy water to get the release agent off
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Forgot all about washing the belts before use, thanks Staggs for the reminder.
This is a whole new learning curve coming from 2 smokers to 4 stokers, thanks for your opinion and it makes perfect sense.
WinterWolf
- Mar 25, 2017
- Connecticut
I've never washed a belt ever...and never had an issue??? I don't think my dealer is gonna wash the belt before they put it on the new sled...are they?? I mean...I gotta be honest, been sledding for a long time, and that's the first time I've ever heard this before. I guess you learn something new every day...
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Been washing new belts since the late 90's. Just completely forgot about it until Staggs brought it up. I'm just getting back into sledding after a 9 year absence. Its coming back slowly but its coming back.
- 8K
