Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
No expert here, looking for advice & help. Caught this belt before I blew it. The fraying is on the outside of the sled. This was my 3rd belt in the same amount of days. Been like that since new, blew my first belt at 3-400 miles. Tried all different offsets/shims. Thanks in advance.
Soupy
- Jan 10, 2017
- West Michigan
Actually I found that my OSP secondary adjuster had backed out slightly and allowed the 8DN to ride up in the secondary so I assume thats what caused this.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Have you tried the stock 8jp belt yet?Actually I found that my OSP secondary adjuster had backed out slightly and allowed the 8DN to ride up in the secondary so I assume thats what caused this.
Soupy
- Jan 10, 2017
- West Michigan
Yes, 6 of them now.Have you tried the stock 8jp belt yet?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Ultimax xs. I blew belts all last year. Knock on wood this belt is workin awesome.
I also put a dalton helix and secondary spring.
Soupy
- Jan 10, 2017
- West Michigan
XS825? Do your clutches run hot? Hot before? Still hot?
Make sure that belt is not sitting to high above the secondary it should be almost flush. If it rides high it may peel off the top of the belt and blow.
Soupy
- Jan 10, 2017
- West Michigan
Hmmmm now that could be a viable resolution. So if too high in secondary, even at idle the primary could damage the belt is what you're saying?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
6? That's one belt per each Brady Bunch kid!
You may need to re-start your whole belt post so every body can remember what you have & have not done...
Yes and when the power is on with a stiff secondary srping it can peel the top off. I talked to Shagman and when he was racing on the asphalt it would start to fray.
Byam
You clearly see that it was probably to high, look inside of your belt. ITwas rubbing on the primary shaft at hidle for sure.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I run my belt just a hair under flush with the sheaves. Dealer told me that during sidewinder school they were told its normal to have the belt slightly sunk in the sheaves. Reason this came up was cause I questioned why my belt wasn't riding out a 1/16th or so.
Soupy
- Jan 10, 2017
- West Michigan
I agree too high in secondary but I've been adjusting more to creep or squeal instead of actual height in secondary. I'll make that change for sure.
Soupy
- Jan 10, 2017
- West Michigan
Could definitely have something to do with my problem!
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Last weekend we put around 600 miles on, no belt dust .last year I had a tin of dust.XS825? Do your clutches run hot? Hot before? Still hot?
Clutches run really cool . Biggest difference was the way the machine shifts now. It's so smooth.
- 14K
- 9K
