Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I've spent some time researching "blow by". And found this to be 100% true in automotive applications. Anything with forced induction is going to experience blow by. The more boost, the more prevalent it becomes. The PVC system on most cars, due to EPA regulations, require the regurgitated air mixed with oil to go back into the intake system. Which everyone in the automotive industry tries to prevent. Vented catch can, oil separator, etc.
The 998t has a vent on top of the valve cover that pushes that same regurgitated air back into the intake. Intern bringing with it more deposits to the valves and intake.
Is there nothing we do to prevent this from happening?
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Some (like myself) bypass the intake and dump it on the ground where it once came from. Some will fit a catch can. When I did my bypass there was a big pit of oil in the intake ahead of the turbo. Took it all apart and cleaned all the hoses, never putting that PCV hose back there. The bypass also keeps that oil out in case you roll the sled.
Have a quick skim through this:
ty4stroke.com
Getting rid of the roll over valve
I don't want the oil in my air box/clutch but don't care to bypass the valve as I never have had a problem with it in 13k miles. I am trying to decide where to vent the hose. Well, I jinked myself. Took the sled out for fall inspection/upgrades and my tank seal is leaking. Upon removal, the...
ty4stroke.com
Doc Harley
- Oct 17, 2016
- Here & there
Ty....I'll give it a good read.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
You answered your own question. If you are concerned about the oil, use a catch can/separator for the PCV line. It really is more of a concern with direct injection engines. Note that the link above is about the roll over valve, different thing altogether.
Turboflash
- Mar 18, 2019
- Southern MN
Even NA engines have blow by. Piston rings don't seal any cylinder 100%. There's always a small amount of compression/cylinder pressure that leaks past. Same goes for valves, valve guides, valve seals.
By itself, normal blow by is not a problem. But it carries oil and other contaminants with it. As you state, there are a few ways engine manufacturers manage it. And yes, more boost equals more blow by.
Many factors affect it. Best we can do is to do our best to minimize it with the basic engine and system design we have. And, keeping engine parts in best state. Getting best possible ring seal starts at break-in. It's why Knapp says when breaking in, ride it like you stole it! You need high cylinder pressure to force rings against cylinder to seat them. Aside from that, make sure valve guides and valve seals are best they can be. Run right oil and right amount of oil (don't overfill). 998 dry sump system helps allot too.
Doc Harley
- Oct 17, 2016
- Here & there
Not concerned, just wondering if anyone feels the need??You answered your own question. If you are concerned about the oil, use a catch can/separator for the PCV line. It really is more of a concern with direct injection engines. Note that the link above is about the roll over valve, different thing altogether.
Just after writing this I went and checked my air filter elbow, nothing in there. I'm kind of surprised?!?!
Very good read, Turboflash...Even NA engines have blow by. Piston rings don't seal any cylinder 100%. There's always a small amount of compression/cylinder pressure that leaks past. Same goes for valves, valve guides, valve seals.
- 166K
