SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Agree...a few times the other day I chose to slide to a stop sign, just playing white nascar in my head and each time, the audible squeal taking off of the convertor not shifted back. Not the best for a belt. Smooth in and out of corners is usually fastest too.ClutchMaster probably nailed it. Maybe thats one reason for me not blowing belts. I like to glide into corner and let the clutch pull me down which helps plant the front... Then throttle through. Now I'm just old & slow. I use my brakes twice a season. Wether I need to or not.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
How hot was it when it blew?will my belt snapped rite into..... there was no other belt parts dwn inside....cleanest break you could ever imagine....i was expecting to see a million pcs ...
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
it wasn't hot.....got rite in there and put new belt on... clutches were only warn to the touch
Soupy
- Jan 10, 2017
- West Michigan
Should be easy to figure out then. At what speed did it break?
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
30-40 mph....got off fuel and rite back on her
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
my buddy and i were playin .. my rtx vs his ltx....his being stock and mine wicked up (270 r) ...we both don't like getting on her hard out of the hole ... we like rollin starts....lol
Soupy
- Jan 10, 2017
- West Michigan
Secondary probably didn't downshift enough. Might need slightly stiffer spring. But with a clean break and if that breakage not happening alot, I might just chalk it up to coincidence.
dem1000
- Feb 15, 2016
- Jokkmokk
- Sweden
- Side Winder MTX 153 -20
m8000 153 -19
Side Winder BTX 153 LE -17
M6000 153 -17
SR Viper MTX 153 -16 sold
Apex XTX -14 sold
Nytro XTX -11 sold
I think that when I drive slowly and hit the gas and the boost increases, the secondary does not shift fast enough due to strong spring or too little angle on the helix. Then it pulls the belt straight off. It happened to me both on hard trail and in deep snow. (Hurricane 270 r)
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
yeah i can see that happening .... mine is 270 race as well ...forgot to put race in my post a couple back....lol... just has so much grunt that I'm not used too
![](/styles/vip.gif)
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Same happened with mine...I think that when I drive slowly and hit the gas and the boost increases, the secondary does not shift fast enough due to strong spring or too little angle on the helix. Then it pulls the belt straight off. It happened to me both on hard trail and in deep snow. (Hurricane 270 r)
Changing my setup to hopefully take care of that.
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
2017 sidewinder ltx le
Barn of parts has one for our machine s, fairy inexpensive for piece of mind.Wow great info
I know a blown belt is inevitable since I still have an 07 Attak. What concerns me is I have seen a few photos of blown out plastic from the belts grenading on the SW. I have never before witnessed a blown belt on a sled resulting in replacing body work. Since there are embarrassingly no parts supply to speak of I guess those riders are frankensled patching these holes and that sucks to me. Even if the part was available sure makes a blown belt more expensive. I'd really like to wrap up a spare belt and keep it under the clutches under some kind of plate to protect the pan and the next victim. I know Belanger sells a piece that seems expensive. Can I use it and place a wrapped spare belt under it? Does anyone know of any solutions for this?
SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
Ok that makes sense. I was thinking it would be too tight right through
THe belt sitting to low will not cause any loss on top end?Belt deflection has no effect on anything past engagement. Hence, no effect on whether a belt blows or not.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
Belt deflection has zero effect on anything past engagement.
You may be thinking a shorter belt, shorter belts will go to a higher top speed only because its starting in a higher gear to start with, and shift to a higher gear at full shift, as long as it does not bottom out anywhere in the secondary at top speed.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Once the sled drives off, and the secondary begins its shift....the helix moves off the adjuster, so now the "shift" or "where belt rides" is determined by the springs. So the deflection will help things on initial drive off, but after the shift begins its all controlled by what components are in the clutches.
Shorter belt on the other hand will MPH more since its a different ratio. Good proof is the longer 8DN vs. Stock shorter belt.
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yep yep ^Once the sled drives off, and the secondary begins its shift....the helix moves off the adjuster, so now the "shift" or "where belt rides" is determined by the springs. So the deflection will help things on initial drive off, but after the shift begins its all controlled by what components are in the clutches.
Dan
Deflection to loose and sled will bog and feel sluggish off the line. That’s about it. If you have notched weights it will trench, rpms will go up down, up down, up down when going at low speeds. No affect on anything after that.
- 17K
