DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
DMCTurbo
- Nov 12, 2005
10000 kms... bearing is like new as I've repacked it yearly. I cant believe I had no vibration.Yikes!!! that shaft is fawked!! How many miles?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I believe member Byam tried one with disastrous results.
DMCTurbo
- Nov 12, 2005
Really well that sucks.I believe member Byam tried one with disastrous results.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
If warranty does not cover it you may be able to have it welded and trued. That would be a much better fit than a production one.
DMCTurbo
- Nov 12, 2005
I was thinking of possibly doing that.If warranty does not cover it you may be able to have it welded and trued. That would be a much better fit than a production one.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yep I have 3000 miles on one , several runs over 330 hp and anti lag. Also know a lot of people using them. Much stronger and lighter than stock.Has anyone used one of these shafts? If warranty doesn't pick up the tab I may go this route.
DMCTurbo
- Nov 12, 2005
Are the tolerances better than stock? Have any worn similiar to the stock shaft?Yep I have 3000 miles on one , several runs over 330 hp and anti lag. Also know a lot of people using them. Much stronger and lighter than stock.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
They could be a bit tighter , I dimple mine and have had zero issues.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Had the same thing happen to my 2 Vipers, I had a machinist friend tig weld and machine the shaft .001" over the bearing I.D. for my machine and then froze the shaft outside and warmed up the bearing/caliper to install together. On my wife's machine the snap ring groove was almost worn right off so I had him repair the shaft size to size with the bearing and he welded a plug inside the shaft which was threaded and then fabricated a cap to slightly preload the rotor and bearing against the snap ring behind the bearing to prevent any movement. Best part of all was I didn't need to remove the sprockets and he was very reasonable with his pricing.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Those are all good fixes. After checking out the BOP threaded wedge...... yea when you need to get it back off just loosen it up.
Nice idea!
Nice idea!
I believe the one Byam tried was aluminum?I believe member Byam tried one with disastrous results.
I agree these shafts should be welded,machined to PROPER SIZE and trued. We need a source for that work. Guy could make a good living doing them I bet!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
The real reason that it’s not a tight press fit is the inability to remove the drive shaft with a tight press fit.
With the BOP inside wedge or loctight at least you can get the shaft to release itself, either buy loosening the screw or application of heat.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
https://ty4stroke.com/threads/aluminum-drive-shaft.155542/#post-1461078
DMCTurbo
- Nov 12, 2005
- 7K
