![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Yes there is a issue. The Taper on bolts bottoms out on the shaft before it is tight enough to squeeze the sheetmetal of the unit. Thats why even though mine were tight and Loctited they still spun wearing the sheetmetal chamfer big time. Only proper fix for this is the new adjuster. My new one tightens enough to squeeze it properly. Shaft is hardened so cannot be modded. Old ones seem close enough that a spotweld would keep it from spinning but the right way is to do both.Where can we get proper fitting bolts? Is there an issue with the taper on the factory bolts?
number1kyster
So, would my 2018 have the updated tensioner?
According to parts fisches yes it should but I wouldnt count on it. I have seen all kinds of things on these sleds that dont comply with the paperwork. Wish they would put a Paint mark or something on the newer parts to id but that would require a minute extra on the line. Only way to know is to remove it and remove screws,clean,check fit,reloctite and then put back on. Other option which is much easier is to just spot weld it and hope that holds.So, would my 2018 have the updated tensioner?
I just looked at the parts fiche for a 2017, no part numbers supercede.So, would my 2018 have the updated tensioner?
What year and model were you looking at Cannondale?According to parts fisches yes it should but I wouldnt count on it. I have seen all kinds of things on these sleds that dont comply with the paperwork. Wish they would put a Paint mark or something on the newer parts to id but that would require a minute extra on the line. Only way to know is to remove it and remove screws,clean,check fit,reloctite and then put back on. Other option which is much easier is to just spot weld it and hope that holds.
Old Part#
New Part #
New Part #
2018 LTX Late Model is listed as the new part # but that doesnt mean anything. Sorry. Only way to know is to actually get hands on or take your chances. They are constantly changing things. This is good but can be very confusing. If it were Yamaha they wouldnt change ever during the year and lucky to change in ten years. I prefer change immediate. At least shows effort. But the downside is you will not know what you have. Welcome to Cat.What year and model were you looking at Cannondale?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
The dam counter sink isn’t cut deep enough into the threaded axle shaft, the bolt bottoms out in the axle before it’s tight on the metal arm.Where can we get proper fitting bolts? Is there an issue with the taper on the factory bolts?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
It’s not the bolts, counter sink the axle shaft threads further. Or just weld it.Where can we get proper fitting bolts? Is there an issue with the taper on the factory bolts?
I looked up a 14 Viper, and it shows the part number supercedes. But when I looked up a 17 Winder, the newest number was standard, that's why I asked.2018 LTX Late Model is listed as the new part # but that doesnt mean anything. Sorry. Only way to know is to actually get hands on or take your chances. They are constantly changing things. This is good but can be very confusing. If it were Yamaha they wouldnt change ever during the year and lucky to change in ten years. I prefer change immediate. At least shows effort. But the downside is you will not know what you have. Welcome to Cat.
glad you checked and caught it in time.
Yes, only 1060 miles. Heading away Friday.glad you checked and caught it in time.
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
Chaincase inspection today. Not cool!
Nice catch, been there...mine was on the inside
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Had you checked at any time before this pic was shot?Yes, only 1060 miles. Heading away Friday.
