Cat DNA Strikes again! -CHAINCASE TENSIONER ROLLER WHEEL FAIL
Yes it would be nice if new part #'s and sled Manufacturing dates could be matched but it seems to be a very broad range. Only way to know for sure is to look. Was same thing for the motor change on Vipers in 16. Some had new and some had old.
I would hope that this would be a recall, with a bulletproof tensioner, as the consequences of this coming apart at speed are catastrophic and could be dangerous. Doesn't take long to replace. Too many instances and no pattern....could be any model. Jmo.
IMO, every single sled needs to be looked at. I know that's a tall order but there's no other way to know.
Agreed. I hoped I had a good one...great belt life, no issues except a missing turbo bolt. But my chain case and tensioner wasnt long for this world...
That’s a Yamaha problem. Arctic Cat had the plastic foot in there for years. No screws to come loose. Yamaha decided to put that wheel in there in 2017.
Vipers have the roller since 2014
Exactly.... That’s when the Yamaha engine went into that Viper. Yamaha went to the roller for improved “durability”. Don’t get me wrong... the cat chassis has many issues... but the roller isn’t their baby.
So you are saying the auto tensioner Cats used to have is a better more reliable system than the roller? Really!
Yamaha wanted a roller
Cat forgot to tighten the screw
Exactly why I never bought a cat, yet this was cat country. One guy gets a good one, another guy gets a lemon. You just never knew.
No.... But they made a simple $50 kit that would make the auto tensioner a manual tensioner while keeping the plastic slider as the tensioner. It had a cotter pin that never failed.... So they got it half right. Lol
This is what Im gonna do, not gonna let this happen again and ruin a trip.
20181202_154828-jpg.143461
I welded mine today but I’m wondering if I used too much heat? I noticed the roller has pin bearings. While my roller still spins freely it makes noise when I spin it by hand. I don’t recall if it was completely silent before. Worried I melted the grease. Do you recall if your bearing spin completely silent when you turn it by hand?
Tack welded my chain tensioner wheel. I’m worried I used too much heat. There is a small needle bearing that maybe the grease got cooked out. The wheel spins easy and freely by hand but it does make noise. Does anybody else’s wheel make noise spinning it freely by hand ?
It might just be a little dry from the heat. Not to worry it will get lots of lube once assembled.
