snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
What secondary spring and wrap do you go with? Mine is same 38 and I have run allens pink spring at 01,but this year I have had luck w/Dalton cat white at 9-1,but secondary much hotter at Dalton white at 9-1 than ulmer pink at 01 w/his pink.Absolutely! Switched to powertrail after being on ECO for 6k. Put 1200 miles on powertrail. 7200 on sled. Running straight 38 for about 7k.
Buckeye
- Lakes Region, NH
They fall in. And sit in the bottom of the case. I don’t see how it could fall out. They rest against a lip on the outer cover which makes the hole too small for the glass to fall through. The glass would have to be broken into pieces to fit through the hole.So when the sight glass's crap out do they fall inside or fall outside the case? Was thinking of jb welding it in place or epoxy?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
TP orange 6/3 on powertrail.What secondary spring and wrap do you go with? Mine is same 38 and I have run allens pink spring at 01,but this year I have had luck w/Dalton cat white at 9-1,but secondary much hotter at Dalton white at 9-1 than ulmer pink at 01 w/his pink.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Pretty tough wrap that spring at 6/3.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes. I did do it by hand. 6/2 is good but I like 6/3.Pretty tough wrap that spring at 6/3.
Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
How do I get that chain tensioner back in the case with everything installed? I had the screws tacked but I am wondering how to install, any tips? Thanks in advance.
Back off the tension screw, push chain over and install tensioner on post.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
yeah back off adjuster a bunch, slide it back on. Be sure to get the spring in correctly...
look at these pics here: https://ty4stroke.com/threads/cat-d...roller-wheel-fail.156166/page-12#post-1471189
Dan
Dan
Spicoli
- Dec 8, 2016
Ok, I figured that. I just was having difficulty with the spring pushing the small end down to rest against the case. Any tricks there?
towman
- Mar 21, 2014
- ontario
- 2014 viper ltx
A small flat head screw driver works good for meOk, I figured that. I just was having difficulty with the spring pushing the small end down to rest against the case. Any tricks there?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Mine went on easy once I had the spring tang held into position. Maybe a screwdriver or something if needed. Pretty straightforward I recall.Ok, I figured that. I just was having difficulty with the spring pushing the small end down to rest against the case. Any tricks there?
Dan
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Take a small dia 1/4" drive deep socket with a screw driver handle on it. Put the socket on the end of the spring and lever/guide it into place. Then the socket slides off the end.
Its a bugger but that worked for me.
MS
MS
Spicoli
- Dec 8, 2016
Thanks for everyone's help, she's in place and buttoned up.
Servicing a 19 SRX with 4300 kms. The bolts did not appear loose but when I put a socket on the bolt they were in fact slightly loose. Both sides which would allow the center shaft to spin. I wonder if that contributes to them coming loose further(the shaft spinning).
Turboflash
- Mar 18, 2019
- Southern MN
IMO, if the shaft (axle) did spin, since the it would be turning counter-clockwise, that would have a tendency to tighten the outside screw but loosen the inside screw. No matter, another example that many/most of these tensioners have loose screws. Ugh!
- 23K
