jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I took my primary off last night. The bolt was tight BUT when I put the puller in I was able to pop it off by just holding the clutch with my hand!. I know this kinda goes without saying(with new sled) but I would suggest people re-torque the primary.
108 pounds then loosen and re toque to 43 I believe. Correct me if I have this wrong?
**108 lb. then 43**
Not saying mine would have come off but man it was NOT nearly tight enough(pressed on). IMO
this is my first Yamaha clutch/sled but it seemed way to loose compared to taking off other clutches in the past.
**108 lb. then 43**
krm
- Apr 22, 2016
- ny
mine did the same 3 weeks ago
- Apr 14, 2003
- Hessel, Michigan
80 pounds then loosen and re toque to 45 I believe. Correct me if I have this wrong?
Yes, torque to 108 ft. lbs. , after clutch is torqued... loosen bolt and re-torque to 43 ft. lbs.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
where do you guys get all the torque specs from?
Here is Torque specs for new clutches from Tech Update book
Please allow edit to save confusion.Yes, torque to 80 ft. lbs. , after clutch is torqued... loosen bolt and re-torque to 40-45 ft. lbs.
Good catch. Could you edit to the new even tighter specs?I took my primary off last night. The bolt was tight BUT when I put the puller in I was able to pop it off by just holding the clutch with my hand!. I know this kinda goes without saying(with new sled) but I would suggest people re-torque the primary.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Steve...is there anything in the new Tech Update book that addresses the belt ride height in the secondary clutch for proper belt tension?
Q. Arrius
- Feb 6, 2015
- Indiana, (central)
- '17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
Does this mean the sleds are coming off the line, with the primary too loose, and should be checked across the board?
Q. Arrius
Q. Arrius
No it means the torque specs for the new clutch is higher than the old clutches. Maybe Cat doesn't know that though.Does this mean the sleds are coming off the line, with the primary too loose, and should be checked across the board?
Q. Arrius
There is. I will get that if no one else does. Is no spring specs and such like in past with new. I still don't agree with setting Deflection on stand other than to get close. It's so easy now. Do in the snow and get it tight as possible without creep or squeal. That's the best way.Steve...is there anything in the new Tech Update book that addresses the belt ride height in the secondary clutch for proper belt tension?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks for the UPDATE on torque specs Cannondale.
I would strongly suggest guys re torque seeing these new specs.
Yes I have a uneasy feeling that you found something here. None of us had a clue till this update came out. Hopefully Cat also got the update before they were built. Personally would not count on it.Thanks for the UPDATE on torque specs Cannondale.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No way My clutch was torqued to the new specs. Maybe mine was random BUT...
And its not like the bolt was loose. So no need to panic but a simple re torque is easy enough
I put this in FAQ at top of list. Is all we can do. Thank You Jon so many here are always observing and thinking,willing to share. Makes this the best site on earth!No way My clutch was torqued to the new specs. Maybe mine was random BUT...
