Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Did some mocking up with measurements tonight. My findings:
-1.220" total primary lateral travel after engagement
-1.030" total secondary lateral travel
Wouldn't this bind up both sideways and belt length after the secondary is fully shifted and the primary is trying to shift a bit more? I understand the primary probably closes a bit more from engagement to when the machine starts to move but I didn't think .200". At full shift, I measured the angle that the belt was on, easily an 1/8" that the belt needed to move over farther inward in the secondary. I was not able to move the primary to the end of its travel with the belt installed no matter how many times I moved the belt, tightened clamps, moved belt, etc. I got it within about .050.
I have 1 shim behind the secondary with offset measurement right at 61.2. Yes, I've blown a couple belts, all stock. Pic of the mockup:
krm
- Apr 22, 2016
- ny
I have had no belt issues so far running one .045 shim behind driven.Sled has over 2200 on it .
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Do you still have both springs in the clutches? The secondary stock Spring is known to coil bind.Did some mocking up with measurements tonight. My findings:
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I don't mean to be Captain Obvious here or undermine your work, but are you sure that ruler is PERFECTLY straight? I have 3 of them & not one is good on the stone table or surface plate when used that way.
I like what your doing. I will do this to mine when it gets home just to make sure there is not something different or wrong.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Another question for all. Do these clutches "torque in"? Meaning, are they offset or out of alignment a bit to let the motor torque align the clutches?
Fleecer
- Jun 13, 2014
- 2019 SRX
With your shim, is your offset tolerance still within spec of .580 to .610??
I' at .595 and would like to get close to .610, but smallest shim yamaha makes to go behind secondary is 1mm or .040. This would put me at .635.....too far. Does anyone know where I could get a .020 shim?
krm
- Apr 22, 2016
- ny
Try 8kc-ra446-00 =.020With your shim, is your offset tolerance still within spec of .580 to .610??
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I'm not going to check my clutches because I have enough crap going through my head with this sled. All I know is I have had zero issues with my belt. 1500 miles and the belt looks almost new. If I had problems like some have reported then I would worry and be checking stuff.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Well if your blowing belts check everything.
Center to Center 264mm +- 2mm
Offset is on the high side, if your blowing belts go on the low side of the offset.
Check and make sure the clutches are parallel. Use the straight side of the straight edge not the flat side.
If you change something recheck all you previous measurements.
I prefer to have the primary with a slight tilt forward (out of parallel) like the old sleds used to spec. Solid mounts or not, the motor is going to flex a little and if it’s already perfectly parallel it won’t be at maximum power.
With the clutches out of parallel (engine tilted towards secondary) it will cause the secondary to open prematurely and lose belt grip. I also would recommend giving the secondary another 10~20 degrees of twist and see where your rpms are at.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
I think his concern here is not so much alignment but how far the primary clutch travels when fully closed in comparison to how far the secondary can open. If the secondary can’t travel as far as the primary then it likely places more stress in the belt. Try doing the same test but remove the secondary spring. If you now have the same travel distance on both clutches than the secondary spring coil bind was the issue. I just changed my secondary spring to a Dalton Black Orange which eliminate the coil bind.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I would think the opposite...if anything I would want slightly MORE offset...
if you are blowing belts heres what to look for...
make sure the metal washer is REMOVED from the osp belt adjuster
check bad primary spring as some early werent good...
primary torqued properly..
roller flat spotting on secondary...
all bushings clean...
no oil on air filter leaking onto clutches
leaks around your belly pan could let the belt get wet and slip...
lack of secondary spring tension for a given power...
and all the others mentioned like ctc...and parallelism although I believe not adjustable...would be good to know ..
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Ok yea sure the primary isn’t torqued properly that’s it! LOL
So you think it’s the opposite and more offset would be better? Do you have any theory behind that? You should try giving your sled a few extra shims under the secondary and see how that works out for you.
I would hope something as obvious as oil spots on the cluches would be noticed.
Look at how clean his clutches are, they are like brand new, and he has been moving them by hand so it’s not a sticking bushing.
As far as the extra .200” of travel... well the belt won’t even move in the secondary for the first .060”~..100 of primary travel because of belt clearance and looseness of the belt.
As far as wet clutches go the winders are pretty we’ll sealed up.
What I told him to check is very pertanat to blowing belts, ask me how I know.
I have heard secondary casting flash can cause the secondary to stick, but I have never seen this but I guess you could have a look.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Symptoms of excessive offset..
Erratic RPM’s under full throttle,
Sluggish back shifting,
Excessive clutch heat,
and last but not least, excessive belt wear.
Symptoms of too little offset...
Hitting the rev limiter,
Sled feels snappy, but doesn’t upshift well,
Mileage suffers.
This is due to the fact the belt wants to run in a straight line, if it’s on an angle going into the secondary sheave it will pull it open (to much offset) and cause slipping. Remember your secondary sets the tension for the entire CVT system.
Mileage suffers.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I’ll ad this
If your clutches are not hot then it’s time to look for binding issues.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I guess i should have worded it...important things to check also...
actually one belt blower solved his by doing that..if your belt shows cord pop on the inside....move out...and outside...move in...if it snaps in half....slip then jerk might be in order...pieces...might jump and contact underside of the belt guard...ask me how I know
I would hope something as obvious as oil spots on the clutches would be noticed.
an oil film might not be readily apparent to a non pro like yourself
with heat a bushing can swedge and not be found by dry cycling
actually they are terrible...from front to back...including the two holes in the tunnel by the rotor..
- 26K
- 45K
