NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
The most common way is a progressives controller based on boost references. Not sure what ski doo is using but probably not as simple as that.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Ski-Doo's system claims zero meth for Appx 12-20 B4 meth is activated. So using vac/map doesn't make sense, as the system is reading boost pressure during that time frame. Must be reading intake temps?!?!
I was just giving the bookends of how it is managed on different installations. It can be as simple as a running engine and vacuum (not everything is boosted) to full table relating Water/Meth injection duty cycle to AFR/RPM. Given the small quantities doo is carrying around I suspect it is there primarily as a safety valve (anti-knock) at high boost so likely pulling pressure data and as long as they have a table for AFR they might as well carry a table for the water/meth injection.
On a side note, will we see aftermarket companies pushing their own water/meth mix? For the guy who looking to just do short lake runs there would be some small benefit to running more methanol and a slight improvement in boost.
Water/meth injection is not a panacea, you are talking about dropping cylinder temperatures ~25 deg and raising octane demand by ~1 to avoid knock. It is smart marketing choice for doo where the obvious win is not having to have a bigger cooling system or justify why it doesn't have one.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Good find! Lol. They don't need longer studs to go fast. But might need them from the dig. They'll figure something out, as we always do. I got my own problems to work on....lol.Well the 850 turbo dreams of a lake racer have vanished. Like consuela would say on family guy, traction, noooo no traction here.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
No but to run with a sidewinder down low is its chance. And having to change drivers and tracks to do it on a 23-24k sled just to use it as intended. It will always be a weapon on trail but meth tank is for lakes/fields not trail. And for trail weapon it would want 1.5” with studs which is also not doable.Good find! Lol. They don't need longer studs to go fast. But might need them from the dig. They'll figure something out, as we always do. I got my own problems to work on....lol.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, it sucks. Always something for skidoo to overcome. Apparently, it has its limitations, that I'm sure they didn't expect. Kidney punch, Kidney punch, low blow!!! Hahaha. Its all in good fun.No but to run with a sidewinder down low is its chance. And having to change drivers and tracks to do it on a 23-24k sled just to use it as intended. It will always be a weapon on trail but meth tank is for lakes/fields not trail. And for trail weapon it would want 1.5” with studs which is also not doable.
Guess what.....there's more to come.
I saw a pic yesterday, dealer in Maine is preparing 6 of these guys for delivery.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
That report on clearance is false...go look on Dootalk. They added clearance at the front of the bulkhead to be able to run the 9 tooth driver, one guy swapped in a 1.5 rip2 with 1.575 studs at the dealer - this was dealer recommended and installed. 68Gmc is doing even longer studs (he has highly modded sleds, both from doo and Yamaha). So they will be able to get traction for sure! Much better pics on Dootalk.
I think this will be a very fast sled off the line, time will tell.
Here is video of 1.64 being installed.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, I'm not 100% convinced of anything. I'm pretty sure box stock it will be good for 115mph-/+ (not Speedo indicated) and that's with the washer pump going full tilt.That report on clearance is false...go look on Dootalk. They added clearance at the front of the bulkhead to be able to run the 9 tooth driver, one guy swapped in a 1.5 rip2 with 1.575 studs at the dealer - this was dealer recommended and installed. 68Gmc is doing even longer studs (he has highly modded sleds, both from doo and Yamaha). So they will be able to get traction for sure! Much better pics on Dootalk.
If we dance around the modified arena, most winders go 130mph+, 140mph+. So, being specific.... How fast are you thinking?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Yes if they swap to an 8 or 9 tooth driver they can. Without it they cannot. Says right in your story, swapped to 9tooth driver.That report on clearance is false...go look on Dootalk. They added clearance at the front of the bulkhead to be able to run the 9 tooth driver, one guy swapped in a 1.5 rip2 with 1.575 studs at the dealer - this was dealer recommended and installed. 68Gmc is doing even longer studs (he has highly modded sleds, both from doo and Yamaha). So they will be able to get traction for sure! Much better pics on Dootalk.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
They now COME stock with 9 tooth drivers, its only the XRS850 turbo that has that driver. No swapping needed...Yes if they swap to an 8 or 9 tooth driver they can. Without it they cannot. Says right in your story, swapped to 9tooth driver.
For the record, I love my Yamacat and dont have one of those 850 turbos, I just hate seeing misinformation.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
You guys crack me up with these comments. "100 mph at 1/3 throttle" lol come on, I love my Winder but I need my tall boots for this thread. Should be fun this winter!
Mototown
- Sep 11, 2018
- Apex 40 th
Ok it’s half throttle, lolYou guys crack me up with these comments. "100 mph at 1/3 throttle" lol come on, I love my Winder but I need my tall boots for this thread. Should be fun this winter!
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Wait... there is a middle position?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Cruise down the trail 105 mph at less than 1/4 throttle on a tuner sidewinder.You guys crack me up with these comments. "100 mph at 1/3 throttle" lol come on, I love my Winder but I need my tall boots for this thread. Should be fun this winter!
Do it easily on mine.
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I'll call BS on that.Cruise down the trail 105 mph at less than 1/4 throttle on a tuner sidewinder.
- 13K
