Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Guys,
I am simply trying to connect my I phone to my flasher which worked great last season. Now when I try to connect through the GAP App I get the error message that Bluetooth is not enabled on my device. My sled key is on, battery at full charge, flasher LED blinking blue. The issue is that my phone is not seeing a Bluetooth signal from the flasher. When I look in my phone I can see other bluetooth devices which I can connect with. However the GAP flasher does not show up as a discoverable device.
I tried connecting and disconnecting the flasher, shutting down and powering up my phone. Like I said, this worked fine last season. Has anyone seen a flasher lose the ability to send a Bluetooth signal?
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Mine is doing the exact same thing today! Worked fine the other day.Guys,
I tried connecting and disconnecting the flasher, shutting down and powering up my phone. Like I said, this worked fine last season. Has anyone seen a flasher loose the ability to send a Bluetooth signal?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How old is your flasher? Go plug it into your laptop and see if their is a firmware update for it. Might help.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Make sure to update to 775 firmware and if you already did re download it!
Also can try to remove gap phone app and reinstall
I had issues around sept and this fixed it
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Another guy I talked to his flasher didn t read all the ecu infothe other day!! I got him to reload 775 and reinstall gap app and it worked!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Thanks guys! I will try that.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Please let us know if it worked!Thanks guys! I will try that.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Now what?
Current firmware should be b0775
Connect the flasher then click 'find device' and it should show you what version you have.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Thanks, but why am I getting the "user unknown, unable to identify device" message?
That I can't answer. Yamamarc may know.Thanks, but why am I getting the "user unknown, unable to identify device" message?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
The gap flasher was found on port 4 which is a good thing. However when I click on "Find Device" I get the "user unknown, unable to identify " message.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
PM Gap he was very helpful and sorted mine out. You may not get a response until business hours though.
Include your flashers number on back of tool to Gap.
Is that something TD would have to send through to your updater.
- 12K
