Yamadog
I've had it with the 4 wheel axle kits! I broke the left side wheel off for the 3rd time in 3 years. 2 were turbo dynamics and this one is J T Racing Products. I keep shearing the bolt off in the axle.
This weekend was the weenie roast and it happened trail riding Friday Morning and caused me to scratch that sled for 2 days of racing. I have another 4 wheel kit and 2 try hubs but did not have them with me and we could not get the broken bolt out of the axle.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Maybe give Larson a try? Probably not going to help. What kind of power?
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
Cat changed rear axle next year. May be better?
Yamadog
They are all held together by the bolt through the rail and a hard impact on the outer wheel just snaps the bolt.
rbell14
Curious why you keep breaking them? What is root cause? Just asking because I've got over 3,000 miles on my JT kit and have never broke one. Is it a HP issue or riding style issue? I just ride trails all the time.
Yamadog
I don't think it is a hp issue it is definitely riding style and under most conditions riding on the rear of the skid because the skis are off the ground.
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
- Viper M-TX 2016 MCX 270
I have billetX rear axle on my machine. Original one broke after only one season.
http://www.billetx.se/billet-wheels/yamaha-tuningfork-design/2x-bxv-10-yamaha-kit
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I’ve been debating a 4th wheel kit or the JT 2-wheel kit. I landed a a jump tail heavy and off center this weekend and snapped a fiberglass rod in my track, probably hard enough it would have broken off a 4th wheel kit too. On the other hand the relatively cheap 4th wheel kit might have absorbed the impact enough to spare the track damage. I’m just glad it broke outside the window and not the center. I hope the new 3 or 4 wheel axle on the 19’s will retrofit.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Maybe consider OFT 3 wheel axle (all between the rails). I use wheels from Avid with a 3 wheel axle from OFT. Replaceable bearings and piece of mind that there are more than two of them back there.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
The Larson one uses a mortise and tennon joint on the outside wheels. The outer cup that holds the wheel fits over the axle that fits through the rail. All parts are billet aluminum. The bolt just holds everything inline and it was a grade 8 with my kit. They use them for the snow cross races and apparently none have ever broken.
TD Max
Not the Larson...
A bit more difficult to install, but as bomb proof as it gets.
Pstn head
What he saidThe Larson one uses a mortise and tennon joint on the outside wheels. The outer cup that holds the wheel fits over the axle that fits through the rail. All parts are billet aluminum. The bolt just holds everything inline and it was a grade 8 with my kit. They use them for the snow cross races and apparently none have ever broken.
Pstn head
YupNot the Larson...
X3
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I have the Larson kit, you won’t break that one!
- 35K
