Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Im still patiently waiting for a new flash. I hope with 16 this problem is a thing of the past.
Studroes144
- Oct 30, 2013
The original ecu update was suppose to cure the problem, it didn't help it, if anything it made it worse for some.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I'm finally looking to fix my starter I'm up in Canada and from the Yamaha dealer they want 550$ for the starter.
I see a bunch on eBay listed as aftermarket fit for under 200$.
Has anyone tried one of the aftermarket ones.
this HTML class. Value is http://m.ebay.ca/itm
Need to confirm but I believe viper uses same starter as nytro/vector. I would have good used oem Yamaha starters for $125 each.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
It's the same starter as the nytro and vector.Need to confirm but I believe viper uses same starter as nytro/vector. I would have good used oem Yamaha starters for $125 each.
Your dealer should cover it. Yamaha covered all my parts when mine went. It
was also out of warranty.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
This is what I find frustrating about dealing with Yamaha through the dealer. You might get excellent service through your dealer, but if I have an issue and my dealer doesn't go to bat for me I basically am on my own.
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
I bought an aftermarket starter it lasted about 600 miles. That was about the same mileage as the original one. The nitro one is the same. I think all the sleds except the phaser had the same starter since 2003 on the warrior. Not 100% sure on that but this is what I remember.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I've read a lot on this issue. It really doesn't look like the starter was ever the problem. More to do with timing and the way the engine would "kick back".
But again i never had the problem so it's just my opinion
Studroes144
- Oct 30, 2013
I never had any kickback issues with mine, it never started good, but always started, mine went at 2800 miles. There's an updated starter that's being put in, I don't think the starter is the issue but maybe the new starter is helping so it doesn't happen again.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Let's hope. All the technology in these machines and the damn starter is the problem.I never had any kickback issues with mine, it never started good, but always started, mine went at 2800 miles. There's an updated starter that's being put in, I don't think the starter is the issue but maybe the new starter is helping so it doesn't happen again.
A few the housing just broke so no pieces in motor. Those guys were lucky ones. Short of a real fix using the starter housing as a fuse may be best we are going to get. Still think they should add a starter clutch.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I agree, It is a Viper issue! Rode with many Nytros and Vectors with the same engine/starter but Yamaha CPU ect. No problems until the Viper. Now people think that they should redesign the starter to solve a Cat problem because its a poor design by Yamaha? Just get Cat to fix their problem! Piss poor CPU and injection.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I agree 100% that the problem is a result of the cat electronics controlling the yamaha engine in a viper. I have never sold a used vector or nytro starter to a customer that had one break like they are in the vipers.
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
I haven't had a problem yet with only 500 miles on my machine, but mine doesn't start nicely at all. Wish Cat would own up to their mistake and crawl back to Yamaha to get help fixing their problem. I would think with Yamaha's name on the line, they would want to do everything possible to fix what is becoming their problem with all warranty work.
I agree 110%
Even with the dealer going to bat I find it tough to get any satisfaction out of Yamaha. Could be because I called them on screwing us RTX LE guys and they are sore about it...
Studroes144
- Oct 30, 2013
This past winter when my starter went bad along with some other things my dealer called the yammi rep and had a conversation with him while I was right there, everything got taken care of 100%, the dealer and the rep both went above and beyond to make it happen.
