Turboflash
- Mar 18, 2019
- Southern MN
Agree as a Cat rider. Just don't see the same rattle on TCats w either Team or ADAPT primaries. I think the weights of the Winder primary is close to Team weight but I haven’t seen actual weights compared to ADAPT.Ya, I just did mine on the new 23 today with the loctite and the kit. Just cant imagine this will do much of anything with the clutch rattle, cant believe I had to try it. Figured it may stop the rattle a bit in that 3500-4500 range, but I should know better.
The 1200 Doo has no stub shaft and splines and it will rattle the clutches like a bucket of bolts too. Cant be helped on a three cylinder four stroke. Just need a good clutch on it, but even my Tapp has the rattle at 4500 or so RPM.
Funny that Cat has clutches that don't rattle on this engine though.....
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
i agree... curious tho how things sound and lube looks after a season.. wont be me due to lack of snow its seems lately but have to get one of u high milers to do a follow upI’ve done three winder s now , all noticeably much quieter. Only question now is longevity
Warren Silliker
- Feb 23, 2016
- New Brunswick
- 2021 Sidewinder SRX
So what is the thoughts on just doing this yourself with a proper Oring and the Grease? once it is back together with oring properly fit inside it cant really go anywhere to get by as it is against the bearing on the inside.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hah ....it's not a bad idea. I can't imagine having anything to lose.So what is the thoughts on just doing this yourself with a proper Oring and the Grease? once it is back together with oring properly fit inside it cant really go anywhere to get by as it is against the bearing on the inside.
sideshowBob
Yes we definitely need conditions that allow us to start riding these sleds before I fix my sled so much that I have it permanently broken!I love this site, best sled site on the interwebs. lots of smart people here.
But only here will you get 8 pages of a discussion about grease.
earthling
If you can justify the machining time and have the materials on hand (free) then go for it but for the cost.. it seems like a lot of effort only to end up where you started. The design/o-ring isn't an issue as far as I can tell, and comments here that it holds the grease towards the engine side where the grease can and likely will leak back towards the engine/crankcase as it breaks down means the o-ring is doing its job. The whole thing feels like a solution that will require seasonal maintenance or maybe every few seasons just based on the comments from TAPP that half the grease should be held in reserve for 'next time'.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
If this grease refilling becomes part of the seasonal maintenance procedure. I still think it a good deal. The small amount of time, to take apart and grease is time well worth the final results in my opinion. Once we get some miles on the kit .Time will tell if its the real deal or not.If you can justify the machining time and have the materials on hand (free) then go for it but for the cost.. it seems like a lot of effort only to end up where you started. The design/o-ring isn't an issue as far as I can tell, and comments here that it holds the grease towards the engine side where the grease can and likely will leak back towards the engine/crankcase as it breaks down means the o-ring is doing its job. The whole thing feels like a solution that will require seasonal maintenance or maybe every few seasons just based on the comments from TAPP that half the grease should be held in reserve
Doc Harley
- Oct 17, 2016
- Here & there
Ive been thinking along those lines. I've had my console and panels off more times this year then the last six combined. I'm done, I'm not done, I'm done, I'm not done.Yes we definitely need conditions that allow us to start riding these sleds before I fix my sled so much that I have it permken!
Something's gotta break soon.
Like stated, I'm ready to start riding. I'm assuming it's another 3 weeks for me as conditions are not even considered sketchy. Think about that.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
I can't believe I read this entire thread....20 minutes of time I'll never get back. I'm with Bob on this, Apex clutch and Hurricane noise reduction ring. This combination is very quiet, and you don't have to worry about anything.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
But what kinda grease you going to useI can't believe I read this entire thread....20 minutes of time I'll never get back. I'm with Bob on this, Apex clutch and Hurricane noise reduction ring. This combination is very quiet, and you don't have to worry about anything.
And how much
LOL
Doc Harley
- Oct 17, 2016
- Here & there
Hmmm....didn't see anything on grease/ how much till page 11. And after that very few posts about it. We are now on pg15.
Guys spending hundreds on a balancer that may not last forever. might not be the best solution either? Hmmm
Do we as a group not completely enjoy Options, or DIY projects?
I think the knockout kit could very well be a homerun, for those that want their clutch quieter. Probably just takes a day or so to do some reseacrch, and find a Particular grease that outshines others by a very large margin.
Lol.....
Lol.....
DennyTuna
- Jan 28, 2017
- Ohio
I do hope it works as intended. It would be a good option for sure for many.
My Hurricane ring has been on my winder since the first year it was out. Zero issues just a very quiet clutch for at least 8,000 miles now.
For me it's not something I want to add to the already long list of yearly maintenance on these sleds.
On a positive note...North of Newberry (Windy Corners) to Pine stump over to Grand Marais got a foot plus of snow 2 days ago....yippee!
Doc Harley
- Oct 17, 2016
- Here & there
Judging by the numbers I'm seeing in many various groups, this little seal kit is going to put 100,000miles this year, in testing. Keep in mind , 40 guys putting on 2500miles is not that hard to believe. so we will get a very good snapshot of things, By the end of this season. Again, could be a grease out there that's working in another area of industry that could easily extend the products ability to keep clutch noise at bay. Maybe one of us has found something and it just needs to be tested b4 bringing it to the groups attention.besides, clutches should be pulled every season, as knappattack stated, it's not a big deal. I just don't want to refill the grease after every ride. Lol.
Anyway.... I saw the snow you speak of, seemed to be in a very tight Corridor. Groomers out, grooming what they can (their words). Not all areas have enough snow. I'm hopeful as you are, just have to stay patient a little bit longer.
Just hate to drive 7hrs+ to bounce off rocks.
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
I just finished my seasonal and additions on my SRX and for whatever reason this knockout kit had a much more dramatic effect than on my older XTX. I did switch to an Apex primary, although I have a hard time believing that was an attributing factor.
Any of you guys that got a kit get any directions?
- 37K
- 49K
