Ok, thanks.No, I have machines running around with no added venting with the TAPP primary, XS belt and proper offset and have never blown a belt. I believe the belt and roller issues I had were all on account of the stock Yamaha primary, so I have no plans at this time to add any additional venting.
Aside from clutching I didn't know if you or others were looking to keep the engine and/or exhaust compartment cooler by adding airflow.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I have a Hurricane add on intercooler. I will let it go for $300
Sent you a PM.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Thats mainly why I like lower moflows and the ones by the knees……….I find underhood heat noticably reduced vs no venting at all. You feel it by the knees when slowing down.Ok, thanks.
Turboflash
- Mar 18, 2019
- Southern MN
I too have added venting similar. More front-facing and more rearward. I can easily feel underhood heat coming out. I have more on right side than left for obvious reasons.Thats mainly why I like lower moflows and the ones by the knees……….I find underhood heat noticably reduced vs no venting at all. You feel it by the knees when slowing down.
AAdavis
- Sep 30, 2019
- Jackson Wy
- 2020 Yamaha Sidewinder SRX
SoldI have a Hurricane add on intercooler. I will let it go for $300
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
JM.02c
An intercooler needs a measurement of time to cool the air passing through it...the faster the air flows through the cooler the less time it has to cool the charge so a bigger cooler becomes more effective for the heat transfer.
Although I feel an intercooler is effective and necessary for our turbo sleds, I think rather then increasing the cooler's size, first its more important to ensure the intake air that the cooler is temperature managing is as cool as possible. In the snowmobile world we are very fortunate to have access to cool ,normally well below freezing temperature, and dense air for our engines air intakes to use.
IMO a true cold air intake to feed the air passing through the intake system is the simplest and most effective way to control intake temps and enhance or maintain engine performance. A cold air intake with a little ram air effect is even better.
For my application I have chosen to go with a true cold air intake, enhanced engine cooling capacity, and full venting to keep all temps as low as possible.
Works for me
Bob would you say the ram air intake is where your getting your higher boost number from?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
The bikes are naturally aspirated and the motor is seeking 100% volumetric efficiency. I would just accept the fact that it's a nice looking, well crafted piece.That's a good question...I have had the Gap ram air on my sled for the last few seasons, right since it first became available, but I never sealed the airbox stock opening until this year. My boost is definitely up about 1 psi this season so that may be why but I don't know for sure. I do think my IATs are a little lower on a long run.
I also remember that when the Japanese sport bikes added Ram Air on their bikes 20 years ago they claimed 10+ hp at speed so who knows![]()
Race cars don't like any boxes. The turbine housing is faced directly into incoming air.
I'd think the boost will be whatever the computer tells it to be according to the map. The ram air will have no effect on boost, but I agree that it lowers IAT's given it's sealing off under hood warmer air.That's a good question...I have had the Gap ram air on my sled for the last few seasons, right since it first became available, but I never sealed the airbox stock opening until this year. My boost is definitely up about 1 psi this season so that may be why but I don't know for sure. I do think my IATs are a little lower on a long run.
Doc Harley
- Oct 17, 2016
- Here & there
But at 70mph+, how much of the under hood air is effecting IAT's? Idk, can't be too much vs an open air filter that's directly in front of the pre-filter or screen on our cowl/hood?!I'd think the boost will be whatever the computer tells it to be according to the map. The ram air will have no effect on boost, but I agree that it lowers IAT's given it's sealing off under hood warmer air.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
It all helps. Not enough snow to ride yet.
Some people are out packing down a little base.
On Bob's sled shouldn't be any.But at 70mph+, how much of the under hood air is effecting IAT's? Idk, can't be too much vs an open air filter that's directly in front of the pre-filter or screen on our cowl/hood?!
On my sled with the under hood CAI, there will be a mix of warm air drawn in.
Doc Harley
- Oct 17, 2016
- Here & there
Hmm..I see. I'm speculating the difference is not enough to sustain any advantage in performance.On Bob's sled shouldn't be any.
Although I do notice Turbo Dynamics specifically calling it out as a must-have, down the road with his bigger tunes. At least I think he does, or did at one time.
I hope Bob knows I've always looked at that piece and wondered how and why.
It has some value, it could just be cosmetics.
justinator
- Mar 25, 2007
- Maine
I plan on testing gap with cap, gap with open top and stock airbox one day…….back to back testing to satisfy my curiosity. I think the cap is needed to make the most of it but we’ll see I guess
I have no way of knowing but even before the gap intake my sled has always made 1 or 2 pounds more boost then the other SWs around here that I am familiar with and more then the posts people have made with similar tunes so I don't know if its my map sensor indication or the sled just makes more boost.Bob would you say the ram air intake is where your getting your higher boost number from?
I talked to Dave at Hurricane a few seasons ago and he looked at my logs and said the sled was making more boost on each of its tunes then it should.
I do know that since I upped my fuel pressure the sled is revving higher and needs more primary weight so its making more power with more fuel so its all good
Doc Harley
- Oct 17, 2016
- Here & there
Bobbbb....what else have you done that you're not telling us...lol. secret secret....
- 21K
